PCGUY112887 Posted July 15, 2007 Report Posted July 15, 2007 Has anyone here ever put the DOHC injectors into a 3x00 engine? I ask because I plan to put them in my 3500 however after reading about how their spray pattern is 2 streams in a V shape... it makes me wonder if they will even function correctly in a 3x00 engine. Should I be worried or am I just paranoid? Thanks. Quote
Andrew Posted July 16, 2007 Report Posted July 16, 2007 well i cant say for sure that the spray pattern would be an issue, but i can say that if they are different flow rate's that it will be a problem. Quote
ron350 Posted July 16, 2007 Report Posted July 16, 2007 Are you talking about this? http://www.usrallyteam.com/injectors.html Man there are lots of different injectors out there. Quote
PCGUY112887 Posted July 17, 2007 Author Report Posted July 17, 2007 These are going into a modified 3500, the flow rate is what I am after... but after seeing someone test a DOHC injector and that it sprays 2 streams, vs whatever the 3x00 injectors do... it makes me worried that it will just spray fuel down the side walls of the intake. Quote
timestalker45 Posted July 17, 2007 Report Posted July 17, 2007 it all depends on the power of ur spark the propper air and spark could make it work u might need a bigger spark and more intake do to exstra gas Quote
