fleetwoodguy79 Posted June 29, 2003 Report Posted June 29, 2003 Well I finally got into tearing into it... I'm down to the front heads, but I am unable to get the head bolts off. They are on EXTREMELY tight! Any suggestions? And also, I got a valve spring compressor from autozone, how do I get the retainer out of the spring when I compress it? Thanks all! Quote
phantomFE3 Posted June 29, 2003 Report Posted June 29, 2003 get a big breaker bar to get the head bolts off, or if you are rebuilding are you going to get new head bolts? if so, it would be easy to use a impact wrench, or if you dont have one of those, a couple drips of croil or penetrating oil on them and let it seap into the threadds and then try it Quote
Robby1870 Posted June 29, 2003 Report Posted June 29, 2003 yeah, do what was mentioned above. Since you are rebuilding and rebuilding for performance, you would be well advised to get brand new head bolts, when you put it back together. Robby Quote
fleetwoodguy79 Posted June 29, 2003 Author Report Posted June 29, 2003 Thanks for the tip, I'll try that... but do any of you guys have any idea how to get the valve keepers off? Quote
brian89gp Posted June 29, 2003 Report Posted June 29, 2003 Compress the valve spring and take a small pair of needle nose pliers to grab onto the valve keepers. There is just barely enough room to get them out. Quote
