dohc v6 Posted July 10, 2007 Report Posted July 10, 2007 I am going to attach a pic. Basically I cannot figure out what the small wire goes to. i thought it was a ground. Also what is the reason for attaching a power wire to the aux post. I am running my battery to the back, but I want to coonect the power wire to the starter and not even attach a wire to the post. But I dont know if it powers anything. Quote
gpchris Posted July 10, 2007 Report Posted July 10, 2007 I dont have one.. It looks like it could be aftermarket. Quote
Supreme Cutlass Posted July 10, 2007 Report Posted July 10, 2007 It's not aftermarket, I have one. I'll go out and look today. Quote
Psych0matt Posted July 10, 2007 Report Posted July 10, 2007 looks like maybe a fuseable link. that's kinda how I did mine on the jimmy, since once you blow the stock one, its incredibly difficult to get it the same way, so i just ran mine to the top post where my amp wire connects Quote
GutlessSupreme Posted July 10, 2007 Report Posted July 10, 2007 my TGPs had/have two power wires for the ABS fuse box that are attached there. could be similar. Quote
rockfangd Posted July 11, 2007 Report Posted July 11, 2007 if you are talking about that red wire that is the fuel pump test wire. When a positive is supplied to the wire it triggers the fuel pump to run Quote
1990lumina Posted July 11, 2007 Report Posted July 11, 2007 The Aux terminal makes it easier to boost the vehicle too, but your car will probably never see cold weather so I doubt you'd care about that lol. Quote
Psych0matt Posted July 11, 2007 Report Posted July 11, 2007 i thought you were referring to the small red one. which one is it? that pic is teh suxors!@ Quote
Crazy K Posted July 11, 2007 Report Posted July 11, 2007 I KNOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Quote
Crazy K Posted July 11, 2007 Report Posted July 11, 2007 it is the positive power supply wire.... for the fuel pump in my cars. yeah I forgot to hook that wire up in the 92 vert swap and it would not run Interestingly, there was a second wire ONLY in my 91 CS (with POWERFUCKUPPERIII) presumably for the PMIII. (although I have not figured out why the wipers were permanently powered) also... You will HAVE to have the battery cable still connect to that post, as all the things in the box beside the the post use it for a hot. abs horn or whatever is in there. Quote
