After ALL LOT of fooling around with easy-outs, I finally got the broken plug out! YAY!
Now, I have a new problem:
Car will not idle. I start it, and unless I press on the gas, it stalls. Erratic idle after warm-up.
Pulled trouble codes from computer, and the diagnostic tool displays "MAP Sensor or low circuit".
Bad MAP sensor or busted vacuum line? If vacuum line, where do I begin tracing?
I really need help on this one. My dad wats his truck back ASAP!
Thanks
Jon
1994 Pontiac Grand Prix
3100 SFI V6
4T60E tranny
On my 3.1MPFI it was just a popped off vacuum line. I'm not familiar with the 3100 engine though, sorry :frown:
Tried three different MAP sensors and two vacuum lines. No change.
Changed ICM/coilpacks, no change.
Can hear a hissing coming from the area of the purge valve solenoid.
Jon
Jon
lol, then fix the hiss
um if not that try and use a smoke machine. connect that to ur vacuum line and if theres a leak it will blow out the smokefrom it my mechanice showed me on a customers car.
Or take throttle body cleaner and spray different areas on the lines. When your idle goes down, thats where the leak is. Don't spray too much though, otherwise you're car might catch on fire
Update:
Changed vacuum lines for nothing. Hiss was coming from the serpentine belt! DOH!
Checked voltage to and from MAP sensor. 4.83 volts reference from the ECM. 0 volts coming from SIGNAL when the engine is running.
Bad MAP sensor or blown computer?
So close I can taste it!
Advice?
Thanks
Jon
u try the wire might be the connecting wire. i just found out my car needs a new relay cable from my speed sensor to my ecm, my speedomiter was going up and down tried every thing replaced vehical speed sensor, and ecm finally after weeks of fighting with it i had it tested and thanks to amco turned out its the wire.Age does damage
I thought about the wire, but I tested for voltage right out of the sensor. I have 4.83 volts going in, and nothing coming out of the sensor.
Then the sensor is bad :lol:
I have a good one for sale cheap.... pm me if interested
Checked MAP circuit.......bad ground!
Replaced MAP sensor. Still no idle.
Checked output voltage on SIGNAL line.......
0.02v key on engine off
0.04 - 0.06 @ idle
0.07 - 0.12v @ WOT
Bad harness? Still bad ground? Where does the ground go for the sensor?
Any ideas? Getting supremely frustrated! :mad:
Jon
I would follow the wire to the ECM. There may be a break in the insulation somewhere. Keep at it, electrical stuff can be tough
Update:
Repaired bad ground from sensor. Sensor functions. No codes.
Car starts, and idles. Doesn't stall. At idle, feels like it's missing. Exhaust gases coming from pcv hole in valve cover. Believe because of running without #3 cylinder and MAP sensor, that raw fuel and carbon caused from rich gas has partially plugged cat. Purchased new converter and will swap next weekend.
If condition still exists after that, will check injectors.
Thanks to everyone who responded with suggestions.
Jon
Depending on how much money you're looking to spend, I would replace the O2 sensor if it hasn't been replaced. That got rid of a lot of my chugging. I spent ~30 with the sensor and the expensive attachment to remove it.
  JBC2005 said:
Update:
Jon
So are the gases from the exhaust system or the pcv valve hole?
If I remove the pcv valve with the engine running, exhaust comes out the pcv hole. I think it's because the converter's clogged.
Jon
Another thing I noticed today, at speeds over 80 KPH (after OD kicks in), the car stumbles a bit. It's fine after it downshifts back into 4th gear.
Could a clogged cat be causing this? Possible O2 sensor failure?
Any suggestions?
Thanks
Jon
Jon
Exhaust cannot be comming from the PCV valve, unless you have some serious internal engine problems.
  Captain Badass said:
Jon
exactly, either you have exhaust leaking from behind the engine or it's emission gasses and you need to change your pcv valve.
