AxlCrucifix Posted July 9, 2007 Report Share Posted July 9, 2007 Not sure if this would be the right forum to post in, but whatever. I just installed a new signal switch in my 89 GP, the switch beneath the steering wheel, and it seemed to be working fine. I crossed the power wire with each of the signal wires (found out which was which from my haynes manual) and they all worked i chopped off the old one, taped them up and it still worked now, i soldered them, taped them, and tried it out With the current signal FLASHER, the signal lights on the right work for a little bit, then stop, and the ones on the left dont work at all. the hazards work on the front, but not the back, UNLESS the signal switch is clicked for the right signals, THEN the back hazard lights work. I tried another two signal flashers, and the signal lights didnt work at all. When i put the first one back in, the right signal lights did the same thing they did before, work for a bit then stop. Its REALLY messed up, I can't understand why its doing this I put the steering wheel back on and now its doing this, why?? Quote Link to comment Share on other sites More sharing options...
Crazy K Posted July 9, 2007 Report Share Posted July 9, 2007 was this a new or used turn signal switch? Quote Link to comment Share on other sites More sharing options...
AxlCrucifix Posted July 9, 2007 Author Report Share Posted July 9, 2007 used from pick n pull here in calgary it was off a 90 and a 91 GP, with the steering wheel controls, i just cut the wires off for the steering wheel controls and used the wires for the signal lights it worked perfectly until i put my steering wheel back on Quote Link to comment Share on other sites More sharing options...
Robby1870 Posted July 10, 2007 Report Share Posted July 10, 2007 I think the cancel cams are different b/n SWRC switches and non SWRC switches....maybe that's the problem Quote Link to comment Share on other sites More sharing options...
synistershadows Posted July 12, 2007 Report Share Posted July 12, 2007 from pick n pull here in calgary YAY!! another calgary member! Quote Link to comment Share on other sites More sharing options...
