RJansen658 Posted July 6, 2007 Report Share Posted July 6, 2007 Ok so today at work I scrapped two late 90's S-10 Blazers, and both had chacoal overhead consoles with compass and temp. Needless to say I took them both as both worked. The color matches my Cutlass perfect, but I may have to modify it to fit the curvature of my roof which should be easy enough. I am more concerned with the wiring to the compass/temp unit. I can get the harness from the donors, but am unsure of the pinouts. The compass/temp unit has 6 wires coming out, 1 being power, 1 being ground, I can see 2 of the remaining 4 being for a temp sensor, but am unsure of the other 2. Would anyone happen to have a pinout for the module? I believe one was from a 97 and the other a 99. At the very least I should be able to remove the module from the console and install it elsewhere. I have two attempts at modifying the console to fit the roof curvature, but it looks easy enough, just pull back the material, and use a dremmel tool to trim the plastic, then re-glue the material over the lip. So yea, if anyone has pinouts... hook a brotha up. Quote Link to comment Share on other sites More sharing options...
BXX Posted July 6, 2007 Report Share Posted July 6, 2007 Does this help any Driver info center 1- with trip computer... power/ground 2- with trip computer.... inputs 3- without trip computer [attachment deleted by admin] Removed to free up storage space. Quote Link to comment Share on other sites More sharing options...
