GutlessSupreme Posted August 26, 2007 Report Share Posted August 26, 2007 the 282 doesn't use that mount plate. only the auto does. the 282 mount bolts directly from the tranny to the subframe. Quote Link to comment Share on other sites More sharing options...
stockgp Posted August 26, 2007 Author Report Share Posted August 26, 2007 aha. shit. i guess i should have left it out, then. oh well. thanks for the info Quote Link to comment Share on other sites More sharing options...
stockgp Posted October 15, 2007 Author Report Share Posted October 15, 2007 on noes. it's almost road-ready. need to get 94+rotors and pads for the new calipers. then, into storage until it's time to start the body work. work since last update, ford yellow top injectors, new throttle body vacuum harness, new plug wires (no plugs yet), new steering column, 5 speed specific ignition cylinder, new clutch hydraulic line and slave cylinder. i tihnk that's it i'd like to get started on a cai, since the factory intake won't fit with the 5 speed motor mount. also, need to flush and fill the coolant, add new oil and filter, and fill the tranny (which i just found out was leaking a bit (shit, shit, shit. i just sold my non-leaking trans to josh). one pic today Quote Link to comment Share on other sites More sharing options...
patgizz Posted October 18, 2007 Report Share Posted October 18, 2007 dan, was your auto bad or did you just want to swap? i need a trans for my TGP to get it moving under its own power before winter so i can tear down the original one and build it up. if your auto is good let me know if you're willing to part ways with it. Quote Link to comment Share on other sites More sharing options...
stockgp Posted October 18, 2007 Author Report Share Posted October 18, 2007 mine only had first gear. that, and i wasgoind to 5 speed swap my 94 gp. this just fell into my lap and was going to be more fun. but if you want it to rebuild or something, you can have it. i'll even meet you somewhere if you want Quote Link to comment Share on other sites More sharing options...
stockgp Posted December 2, 2007 Author Report Share Posted December 2, 2007 well, it's official. there is another functional 5 speed tgp in the mix. tonight was the first startup, and it went pretty well. idles very smooth, even without an idle relearn. there are a few issues, however. first, there is a bit of a tap. seems like every 60 degree v6 i've ever had has a bit of a tap, though. i'm going to check the oil level again and top it off if need be. hopefully i'm just a little low? second, the every once in a while i'll hit the brakes and the car stumbles. once it stumbled badly enough to stall. maybe an idle relearn will help? last (i think), the check gauges light is on. i understand it's a common problem with the tgp cluster. i'm hoping that's all it is and not something else. the 94+ brake swap is complete, minus the ebrake. now i just need to put the interior back together and clean it up a bit. i might get some pics. if i do, they'll be the last ones before the car comes out of paint. Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted December 2, 2007 Report Share Posted December 2, 2007 Awesome man! The check gauges light on can be fixed by resoldering your cluster. There is a how-to on the regular w-body.com site. Quote Link to comment Share on other sites More sharing options...
stockgp Posted December 2, 2007 Author Report Share Posted December 2, 2007 i've read it. i'm just hoping there isn't another underlying problem Quote Link to comment Share on other sites More sharing options...
greencutlassdrvr Posted December 2, 2007 Report Share Posted December 2, 2007 looks good bro nice job Quote Link to comment Share on other sites More sharing options...
stockgp Posted December 2, 2007 Author Report Share Posted December 2, 2007 well, the check gauges light isn't just the cluster. if i pump the brakes a bit the light will go off for a second and the engine stumbles. so, there must be a vacuum leak somewheres. however, would a vacuum problem trip the check gauges light? Quote Link to comment Share on other sites More sharing options...
Crazy K Posted December 2, 2007 Report Share Posted December 2, 2007 probably not on a obd 1. where your paperclip? Quote Link to comment Share on other sites More sharing options...
stockgp Posted December 2, 2007 Author Report Share Posted December 2, 2007 very high-tech, ken. i have yet to check for codes. the ses light isn't on, so that wasn't the first thing to cross my mind. i'll run coedes tomorrow Quote Link to comment Share on other sites More sharing options...
slick Posted December 2, 2007 Report Share Posted December 2, 2007 It could throw a code, say for example, if it is throwing off MAP sensor readings. Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted December 2, 2007 Report Share Posted December 2, 2007 Thats VERY common of TGP clusters for the CHECK GAUGES light to be on all the time, to flicker, or flash. Resolder the cluster pins and it will go away for good. Quote Link to comment Share on other sites More sharing options...
RangeStang Posted December 3, 2007 Report Share Posted December 3, 2007 Sounds like a lot of time and hard work congrats on it running. Have any pics of the interior after the swap? Does it look stock? Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted December 4, 2007 Report Share Posted December 4, 2007 Awesome Dan! This Is Sweet! Quote Link to comment Share on other sites More sharing options...
Grand Moff Joseph Posted December 4, 2007 Report Share Posted December 4, 2007 Congrats! Quote Link to comment Share on other sites More sharing options...
stockgp Posted December 5, 2007 Author Report Share Posted December 5, 2007 well, ran codes. all i got is the old one, two. she's still trying to stall if i hold the brake pedal down any ideas? Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted December 5, 2007 Report Share Posted December 5, 2007 vacuum leak....? Quote Link to comment Share on other sites More sharing options...
stockgp Posted December 6, 2007 Author Report Share Posted December 6, 2007 i don't know. seems odd to me that now it only wants to die when i hold the brake pedal in. other than that, it's a smooth idle. i bought some carb cleaner. i'm going to see if i can find a leak Quote Link to comment Share on other sites More sharing options...
