anyone have a measured drawing of their turbo support bracket
i think iposted this elsewhere, but i can't find it. sorry, mods, for making another.
do any of you gents that have done a 5 speed conversion have a cad (or somthing similar) drawing of your turbo bracket?
i'll need one in the coming weeks, and i don't do metal fab. so, i'll need measurements to give someone so they can fab one for me.
thanks in advance for any help.
it's going to be difficult to weld the pieces together at the right angles without having the tranny/turbo there and in place to measure and test with...
i have mine of my car that i will no longer need, but its from a getrag 284 so it might be different
He's right, I watched TGPvsTIII, a guy on TGPforums.com do mine and you have to do it on the vehicle. If I recall, you mount both supporting brackets on both transmission and crossover, then keep cutting down a firm peice of metal till you get the size you need, then super glue in place, let it sit for a day, pull off carefully, then weld in place.
well, that blows some big old donkey nuts, doesn't it?
kuntzie, mind if i try yours out? if it works, i'll buy it from you. and maybe i can have a couple more fabricated while i'm at it.
it will be a bit before i'm ready for it. i tore into the car today. i'm going to try to get the automatic out today. i'm just having trouble seperating the ball joint from the control arm.
Pickle fork????? I had issues with the tie rod end, but a pickle forked worked well and got it out.
it finally came out. i was using a "pickle fork." i was just trying to do it with the rotor still on. once i took it off the knuckle and rotor, and went at it from the front it came right off.
Just take a big hammer and pound on the spindle where the ball joint goes into it. A couple good hits is usually all it needs to get them apart. Also, it's best to turn the wheel all the way for a good angle to hit it.
