89GPSE Posted June 24, 2007 Report Posted June 24, 2007 I tried to search it, and I'm sure it's around somewhere, but where is the write-up on how to remove the crossover pipe? I have got mine most of the way unbolted but there are 2 bolts I can not get to. The rear bank lower bolt is right on top of the downpipe making it almost impossible to fit anything in there to remove it, and the lower most rear bolt on the turbo is giving me trouble too. Anyone with experience know how to get to these? Possibly with pics? Quote
GOT2B GM Posted June 24, 2007 Report Posted June 24, 2007 i use a 13mm stubby wrench for the bottom downpipe bolt. Try adding extensions and/or a swivel for the rear x-over bolt. This thing should be easy compared to that S4. Quote
Garrett Powered Posted June 25, 2007 Report Posted June 25, 2007 its actually quite easy once you get two or three extentions and a wobbly. you gotta fish the extensions in from the turbo side and push on the down pipe to get it through and underneath there. Quote
mfewtrail Posted June 25, 2007 Report Posted June 25, 2007 Kenny has a writeup in the "How Do I" section on the TGP board. There are probably other writeup posts there as well. Quote
Guest Posted June 25, 2007 Report Posted June 25, 2007 I usually get like 12-16 inches worth of extensions and a deep 13mm socket and go under the turbo and everything from the front. should fit like a sock. Quote
intern8tion9l Posted June 27, 2007 Report Posted June 27, 2007 xWhatever...extensions and swivels are your friends in this case Quote
