pwmin Posted June 23, 2007 Report Posted June 23, 2007 my tranny is leaking, so i think im going to have to pull it apart and reseal it. 1) there is a leak coming from the bolt being pointed out with a black arrow. it is not tight, but when i turn it, it feels like it has some weight to it and wont tighten. is there a nut or something on the other side or is it supposed to be like that 2) i was told that if i tear it apart and something happens to the seal in the part pointed out by a red arrow, i will not be able to find a new one to replace it with. is this true, and if so, what is he talking about and does anyone have the part i will need. 3) what is the easiest way to reseal it. im assuming ill have to pull it? and is there anything i should do while i have it apart. seems like i have some stupid questions, but dont worry, it will get put back together correctly. i just havent ever had one of these manuals apart. here is the pic: Quote
pwmin Posted June 27, 2007 Author Report Posted June 27, 2007 anyone? someone here has had to have torn one apart before. Quote
89GP_SE Posted June 27, 2007 Report Posted June 27, 2007 The only thing I can help you with is the seal problem. Silicone gasket always works for me. Quote
