Addicted To Boost Posted June 28, 2007 Report Posted June 28, 2007 Thanks Matt. I found the fitting, and will probably be charging up the system tomorrow. Are there any places that are common to leak that I should check before I charge it up? I already cleaned up the high and low side spigots and made sure that they don't leak, just wondering if there are any other common leak spots.. Thanks again! Nick Quote
GOT2B GM Posted June 28, 2007 Report Posted June 28, 2007 well, if you disconnect any lines, be sure to replace the o-rings at those connentions......other than that I'd say charge her up and see what happens. Quote
Addicted To Boost Posted June 30, 2007 Report Posted June 30, 2007 GAH! My Freeze 12 cans have spigots on them too small to fit my filler hose! I've already checked the local dealerships and all of the auto parts stores, heck even the hardware stores, and nobody has a filler hose or an adapter to fit the cans.... how has everyone else done this?? Quote
mfewtrail Posted June 30, 2007 Report Posted June 30, 2007 Hmm, Nick. The last time I used Freeze 12(a few years ago), I filled the system I was putting it in by using a side-entry can tap & a manifold gauge set. This is what a side-entry can tap looks like. http://www.sjdiscounttools.com/mas85530.html Quote
Addicted To Boost Posted June 30, 2007 Report Posted June 30, 2007 So on that tool- my Freeze 12 can fits on one end, and my 134 hose will fit on the other end? Is that how it works? Thanks for the help! Quote
Addicted To Boost Posted July 1, 2007 Report Posted July 1, 2007 bump for the above question plz and thx Quote
mfewtrail Posted July 1, 2007 Report Posted July 1, 2007 Nick, you open up the clamp and put the can inside of it(there's a little pin in it like a normal can tap, but it will pierce into the side of the can instead of the top like the typical ones). When you have the can inside of it and clamp it shut, it pierces the can. You're going to want to clamp it near the top of the can. Your fill hose will attach to one of two fittings on the tap. Quote
Addicted To Boost Posted July 1, 2007 Report Posted July 1, 2007 Ok thanks, Matt- I think I'll get one of those. Wewt for 1000 posts! Quote
