KrazyCutlass1995 Posted June 27, 2003 Report Posted June 27, 2003 i recently noticed my cutty running at 1500 rpm instead of 1000 like it used to ... anyone know why this may be ? or is it just normal ... if not how to fix it , i was thinking reseting the computer but i am not sure .. thanks guys Quote
Robby1870 Posted June 27, 2003 Report Posted June 27, 2003 resettin the Comp is a good place to start, and the cheapest. Next, I would try the TPS and/or the IAC valve. Is your Throttle Body dirty?? Try looking at it. It may be all gommed up and dirty. Robby Quote
Baddflash Posted June 27, 2003 Report Posted June 27, 2003 Yeah go buy some intake cleaner and clean the throttlebody and ports and stuff. Start it and spray some though it reving enough to keep it running. Then take it for a good drive and it should fix it's idle. Also disconnecting the comp might do it to, might have to do both. Quote
KrazyCutlass1995 Posted June 27, 2003 Author Report Posted June 27, 2003 thanks ill try the comp , then if nothing clean the throttle body , thanks guys Quote
