stryker Posted June 17, 2007 Report Posted June 17, 2007 How hard is it to put one of these in a W-body? Looks like a tight fit to me. Quote
GP1138 Posted June 17, 2007 Report Posted June 17, 2007 Wh.... huh? I installed a water pump in my car and it was not hard... you mean to replace it? It is not hard. Only hard part is getting the bolts off of the pulley since it spins, even with the belt on it can be a bitch.. some people put a wrench in between the bolts, I put a wrench on one, loosen two, and then put a wrench between the loose ones to get the others out. Quote
Crazy K Posted June 17, 2007 Report Posted June 17, 2007 How hard is it to put one of these in a W-body? Looks like a tight fit to me. pull the coolant reservoir from the car for clearance! LOL Quote
GP1138 Posted June 17, 2007 Report Posted June 17, 2007 How hard is it to put one of these in a W-body? Looks like a tight fit to me. pull the coolant reservoir from the car for clearance! LOL x2! It's easy, truly! Quote
digitaloutsider Posted June 17, 2007 Report Posted June 17, 2007 Werd. I can change out a 3.1 water pump in about 20 minutes. Quote
z34duck Posted June 17, 2007 Report Posted June 17, 2007 cake once you get the overflow jug out of the way so you can see what you are doing ive done lots of them. buy a delco pump they cost a little morebut well worth it Quote
stryker Posted June 17, 2007 Author Report Posted June 17, 2007 I didn't want to but I got a pump from Autozone. It was only $20,warranted for life. I just looked the car,now that me and it both have cooled off and it looks pretty simple to me. I figured it was the pump,water was running down the belt right under the pump and puddling on the ground. I will replace it tomorrow evening after work! Quote
