briandors Posted June 26, 2003 Report Posted June 26, 2003 My factory fog lights appear to be aimed way too far down (as almost every manufacturer seems to do from the factory). Is there a simple adjusting screw to level them? Brian Quote
Guest RedCutlassSL Posted June 26, 2003 Report Posted June 26, 2003 yeah, its a spring loaded bolt behind the light Quote
jesse Posted June 28, 2003 Report Posted June 28, 2003 Is a black plastic thumb screw, up and down is all you have. Adjust them every month or so because they will move. Quote
briandors Posted June 30, 2003 Author Report Posted June 30, 2003 thanks. driver's side adjusted fine, passenger's side just clicks as i turn it. i assume the screw is too far out, so it's off the threads? Unless it's stripped.... guess i'll put it up on ramps to get a better look. Quote
