pradecki Posted June 7, 2007 Report Posted June 7, 2007 Do any of you know if I used a turbo 3.1 if it would work on the 4T60-E. What are the differences between the ecm in the '89 '90 turbo version versus the later non-turbo ones? Quote
Garrett Powered Posted June 7, 2007 Report Posted June 7, 2007 short answer is --->no. ecm---> I think is the same for OBD1 cars. Quote
slick Posted June 7, 2007 Report Posted June 7, 2007 Although, the 3.4 DOHC did use the -E with OBD 1. I'm sure if you could get the trans code info and apply it to the 3.1 chip, it may work. Don't quote me on it though, I have absolutely NO programming experience with automobiles. Quote
Dark Ride Posted June 8, 2007 Report Posted June 8, 2007 Although, the 3.4 DOHC did use the -E with OBD 1. I'm sure if you could get the trans code info and apply it to the 3.1 chip, it may work. Don't quote me on it though, I have absolutely NO programming experience with automobiles. Did the LQ1 use a 4t60-E or a 4T65-E, the wiring harness couldn't be too much different although it would take some work. Quote
slick Posted June 8, 2007 Report Posted June 8, 2007 4t60e-hd. The 4t65e wasn't available until the 2nd gens. Theres a bit more than just a harness change involved. The 4t60 and 4t60e are both controlled by vacuum. The 4t65e is all electronic. Quote
The Master Posted June 8, 2007 Report Posted June 8, 2007 I thought the "E" standed for electronic control? Quote
Addicted To Boost Posted June 8, 2007 Report Posted June 8, 2007 I thought the "E" standed for electronic control? Correct. The E version is electronically controlled. Quote
slick Posted June 8, 2007 Report Posted June 8, 2007 It is, to an extent. It isn't fully electronically controlled. There is still a vacuum controlled shift modulator. Quote
pradecki Posted June 8, 2007 Author Report Posted June 8, 2007 I'm not htat familiar with ECMs .Does the '93 ECM control when the car shifts or what actually tells the tranny to shift? If so how was shifting actuated by the '89 and '90 non-E trannies? The other alternative is to keep the '93 ecm and just add the turbo. Would the ECM be able to detect the increase air and automatically increase the fuel output or what? Is there some type of readout I could hook up to my ecm to program more fuel? Is there any good resource with information about how ECMs function/how to program them/re-flash them etc.? Quote
Dark Ride Posted June 8, 2007 Report Posted June 8, 2007 It is, to an extent. It isn't fully electronically controlled. There is still a vacuum controlled shift modulator. if you could get the wiring right and get the 4t60e-hd in would it work with boost? I know the vacuum modulators on the TGPs are special. how does the 4T60e-HD compareto the regular 4t60-hd strength wise, would it hold up better or worse? Quote
slick Posted June 8, 2007 Report Posted June 8, 2007 It is, to an extent. It isn't fully electronically controlled. There is still a vacuum controlled shift modulator. if you could get the wiring right and get the 4t60e-hd in would it work with boost? I know the vacuum modulators on the TGPs are special. how does the 4T60e-HD compareto the regular 4t60-hd strength wise, would it hold up better or worse? Truthfully, yes, you could get it to work right. Just look at any 1st gen 3.4 guy that's turbo'd his car. All 3.4 cars got the 4t60e-hd or the 284. Whats different about the vacuum modulator in the tgp and the NA cars? I've never heard of any difference. Really, as far as internals go, I don't think there is much difference, other than some electronics. But, I'm no trans expert. Quote
GutlessSupreme Posted June 8, 2007 Report Posted June 8, 2007 I don't think the modulators are any different. The turbo trannys have a check valve in the line right before the modulator, I don't think the N/A ones do. it's just a ~$2 3 way valve you can get at autozone. Quote
Dark Ride Posted June 8, 2007 Report Posted June 8, 2007 The one in my TGP is much smaller than a NA one, but I don't have a check valve in the line. I should take a picture to compare. Quote
GutlessSupreme Posted June 8, 2007 Report Posted June 8, 2007 The one in my TGP is much smaller than a NA one, but I don't have a check valve in the line. I should take a picture to compare. there should be, otherwise you will have hard shifting problems. You must have an aftermarket/replacement modulator, the original was huge too. Quote
Addicted To Boost Posted June 8, 2007 Report Posted June 8, 2007 Yes, on your TGP, you MUST have a 3 way check valve or it will shift extremely hard... when I bought my TGP, it didn't have a check valve on it and it shifted so hard it almost squealed the tires on all shifts New check valve fixed it. Quote
Dark Ride Posted June 9, 2007 Report Posted June 9, 2007 Well it does shift hard with vacuum but under boost it seems to shift fine. I'll go buy a check valve like you said and see if that helps. Thanks P.S. Sorry for the Thread Hi-jack I'm not htat familiar with ECMs .Does the '93 ECM control when the car shifts or what actually tells the tranny to shift? If so how was shifting actuated by the '89 and '90 non-E trannies? The other alternative is to keep the '93 ecm and just add the turbo. Would the ECM be able to detect the increase air and automatically increase the fuel output or what? Is there some type of readout I could hook up to my ecm to program more fuel? Is there any good resource with information about how ECMs function/how to program them/re-flash them etc.? I'm pretty sure you would need to program the Ecm to recognize the boost and add more fuel, larger injectors and a better fuel pump would probably also be in order. Hopefully some other members will be able to answer your questions about tuning, cuz I know very little about it. Quote
pradecki Posted June 9, 2007 Author Report Posted June 9, 2007 what does the "-HD" stand for that you were referring to earlier? heavy duty...lol or what? Quote
Dark Ride Posted June 9, 2007 Report Posted June 9, 2007 what does the "-HD" stand for that you were referring to earlier? heavy duty...lol or what? yup, TGPs and appartently 3.4 DOHCs got them Quote
mfewtrail Posted June 10, 2007 Report Posted June 10, 2007 One of the chip tuner's here may be able to combine the TGP code w/ the code necessary to control the 60-E. Send a private message to "TGPilot" on the board here and he can probably help you out... Quote
kuwaitliberation Posted June 10, 2007 Report Posted June 10, 2007 It is, to an extent. It isn't fully electronically controlled. There is still a vacuum controlled shift modulator. if you could get the wiring right and get the 4t60e-hd in would it work with boost? I know the vacuum modulators on the TGPs are special. how does the 4T60e-HD compareto the regular 4t60-hd strength wise, would it hold up better or worse? I thought you had to have the 4t60 trans that went with the turbo due to the fact that you would tear the trans up really quick. The turbo has different gears and gear ratios than the standard one does, IIRC. Quote
