95 BLKDOUT Drop Top Posted June 5, 2007 Report Posted June 5, 2007 just cracked my mono leaf yesterday, now the car sits lower on the passenger side. I guess itll be parked until i can get somethin to replace it. I kno i can get a new one for relatively cheap off of some1 on the classified section but i was wonderin if there were any companies that makes a coil over conversion now since FFP doesnt make them or even a steel monoleaf, whos dumb idea was a fiberglass leaf? Also, is it me or does the rear sway bar look super puney?? is there anyone who sells a thicker one, mine looks like its on its way soon. also, solid trailing arms Quote
jeremy Posted June 5, 2007 Report Posted June 5, 2007 I think anything coilover wise will now have to be custom. I am not sure how far Bedford is from SE michigan but I do have a rear monoleaf removed from a '96 Cutlass Supreme with 56k Quote
pwmin Posted June 5, 2007 Report Posted June 5, 2007 look at the sticky at the top. i have a reply about making your own coilovers Quote
95 BLKDOUT Drop Top Posted June 5, 2007 Author Report Posted June 5, 2007 i was just lookin on ebay to see what coil springs i can use to custom make a set of CO's. Bedford is about 10 min south of cleveland Quote
CSI_MuNkY Posted June 5, 2007 Report Posted June 5, 2007 Held Motorsports makes coil overs for the front and rear, I just ordered a set. You have the option of spring rate and they offer 3 different levels of coil over package. The rear sway bar is puney! That I know of there are 2 companies making ones that are 7/8", G-max and Addco. I've noticed super long wait times for the addco bar, I just ordered the G-max bar from P-S-T they had 2 in stock so there will be no delay in shipping. I also just ordered Helds lateral links and Trailing arms, I have an Aweb RSTB and will probably end up building my own FSTB (theres no way I'm paying $80+ for something I can weld up myself with $15 worth of steel) My total cost so far is around $1350 USD, but it depends on how extreme you want to go, I'm pretty much going all out here. Jamie Quote
xtremerevolution Posted June 5, 2007 Report Posted June 5, 2007 I'm using a Flex-A-Form custom fiberglass leaf, and I'm very happy with it. 2" drop and much stiffer than stock. Holds up very well on very hard corners and bumps with 2 full grown adults in the back plus a full trunk and a sub box weighing 92 lbs (4 of us went out for a fun ride one night). Quote
95 BLKDOUT Drop Top Posted June 6, 2007 Author Report Posted June 6, 2007 Is there a price for the Held motorsports front and rear CO stage 1 package, my struts are damn near brand new. The thing use to ride like a ferrari before the leaf cracked. Im gonna do all new suspesion front and rear as the summer goes on. (tie rod ends, ball joints, control arm bushings, sway bars+bushings, trailing arms+bushings, etc.) any polyurathane bushings out there? Quote
95 BLKDOUT Drop Top Posted June 7, 2007 Author Report Posted June 7, 2007 jeremy how much do u want for that leaf Quote
