19Cutlass94 Posted June 4, 2007 Report Posted June 4, 2007 How do I go about removing this ring? It looks like its just pressed on, but I dont wanna break it trying to get it out. I need to get the ring out so I can use the ud pulley since none of them come with this ring on them already. Any help would be great. Thanks --Jay Quote
Brian P Posted June 4, 2007 Report Posted June 4, 2007 yup, just pressed in. Tap lightly around it from the inside, I think I used a piece of wooden molding and placed it between the spokes, and tapped it out. Go around slowly, you'll be fine. Quote
19Cutlass94 Posted June 4, 2007 Author Report Posted June 4, 2007 Now I would assume that its gotta to back into the new pulley the same exact spot it came out of the old one? I cant imagine you can just place it anywhere you want? Quote
Brian P Posted June 4, 2007 Report Posted June 4, 2007 reference the timing reluctor ring to the keyway in the pulley. It can be close but doesn't have to be perfect. Computer will relearn it. If you had a '98+ you'd need to do a "case learn" but you have the OBD1.5 which takes anything. Quote
19Cutlass94 Posted June 4, 2007 Author Report Posted June 4, 2007 Awesome. Thanks a bunch. I just need to find something to use to press it back in that would give even pressure. Quote
greencutlassdrvr Posted June 5, 2007 Report Posted June 5, 2007 Awesome. Thanks a bunch. I just need to find something to use to press it back in that would give even pressure. i use pb penetrating lube around it and a punch and came out easily with out breaking a sweat Quote
