Help!
Ok so yesterday my alternator died. So it has been replaced. Now it idles like well shit. When i stop in gear it wants to die, when i start it it wants to idle up higher then normal and then settles down. I did the idle relearn thing and it didn't seem to accomplish anything. HELP!
Sure you did the idle relearn correctly??
I always find after I did the relearn it still wasn't 100%, but overtime it's figure itself out...by the sounds of it you didn't do the relearn properly though.
1. Pull ECM fuse, replace it after a couple seconds
2. Start car and put it in gear with all the accessories OFF
3. Hold it in gear for 5-7mins (I normally do 6 mins as a happy medium)
4. Shut off car after 6 minutes. (Ialways shut it off in gear, dunno if it matters)
5. Repeat steps 2-4 again.
6. Idle should be learned.
Did you unplug a sensor at all?
Did you pinch a wire at all?
