hell_raiser Posted May 28, 2007 Report Posted May 28, 2007 any clue if i can do this with a bfp big fing pipe and some ratchets and sockets any special tools needed Quote
19Cutlass94 Posted May 28, 2007 Report Posted May 28, 2007 no special tools needed. You need to take out the bolts that hold it into the subframe, the ball joint, and the sway bar bracket. All can be done with a socket, breaker bar and a pipe. Maybe a little heat to help if you have it Quote
hell_raiser Posted May 28, 2007 Author Report Posted May 28, 2007 yeah its all of but the mettle inner part of the lower control arm is sized :mad:and the pin is broke for the steering rack also how do you pop an axel Quote
Bake82 Posted May 30, 2007 Report Posted May 30, 2007 yeah its all of but the mettle inner part of the lower control arm is sized :mad:and the pin is broke for the steering rack also how do you pop an axel to pop the axle, take a medium size crowbar on the end of the axle and pry gently and it'll pop out Quote
