hell_raiser Posted May 27, 2007 Report Posted May 27, 2007 i have a good question! can you replace the H member i guess thats what it would be called or fount sub frame? i ask this because i side swiped a civic lol. and my control arm bent and my tire rubs my fender lol i drove it 3 kms like this lol. it only rubs wen turning so what im asking is how much work this would involve i know i have got to take all the suspension apart lower engine mounts ext but what about exhaust and fluid lines has any one ever done this? buy the way its a freshly rebuilt 3100 and mint interior sedan 95 cutlass sl Quote
hell_raiser Posted May 27, 2007 Author Report Posted May 27, 2007 lol whoops the search thing works well duh but a step by step[ would help this 17 teen year old Canadian out Quote
GP1138 Posted May 27, 2007 Report Posted May 27, 2007 It's called the subframe, and yes it can be replaced, but are you sure it's actually the subframe that needs replaced? The control arm can be replaced independent of the subframe. Quote
hell_raiser Posted May 28, 2007 Author Report Posted May 28, 2007 the mounts appear to be bent where the control arm attaches stupid thin tabs Quote
PCGUY112887 Posted May 29, 2007 Report Posted May 29, 2007 Try to straighten them out and replace the control arm. I have never heard of a subframe on one of these cars getting f-ed up. Quote
ismellrealbad Posted May 31, 2007 Report Posted May 31, 2007 well you will if u slide into a curb at 55mph with the wheel turned like i managed to do one night. bent the control arm almost 90 degrees down and back, bent the subframe and mounts for control arm, tie rod end 45 degrees, strut assembly, completely disintegrated front rim and tire, merely destroyed the rear rim and tire and bent the rear wheel bearing. it was such a hard impact i thought for sure i had bent the subframe bad enough to bend the unibody as well. enough so i wouldnt be able to mount up a new one. well got another and it mounted up fine no body damage. i think it took about 3-4 hours with a lift and me and one other person..and a third for the last hour. its not complicated, but it is a fucking bitch if you dont have top engine support fixture and a jack that will sufficiently lift something that large and bulky. of course i did not have these things. it was a complex and rediulous combination of moving people and stand up jack to different locations at differnt times when removing and installing the subframe. something to SAFELY support the motor and trans from above the car is the most important thing. it may actually be easier to do on the ground Quote
