RobertISaar Posted May 27, 2007 Report Posted May 27, 2007 whats everyone think of this and what would it be good for? T3/T4 Hybrid Turbocharger 0.50 A/R Cold Side 0.58 5-Bolt Standard Hot Side 3†Inlet Diameter 2†Outlet Diameter 0.50 Compressor Wheel Trim 0.50 A/R Compressor 0.63 A/R Turbine 57 Trim Turbine Wheel: Exducer : 2.48" Mayor : 2.89" Compressor Wheel: Exducer : 2.07" Mayor : 2.36" 25-35 PSI Peak Power Performance Output Capability CNC Machined Flanges if nothing else a good site for explaining what all the measurements will mean Quote
RobertISaar Posted May 27, 2007 Author Report Posted May 27, 2007 since no ones biting on that one how about this: T70 Turbocharger DESCRIPTION Brand new in box Inlet (Exducer/Hot Side) T-3 Flange 0.84 Exducer A/R 0.70 Compressor A/R Cooling/Lubrication Oil Outlet (exducer/hot side) 3 " V-Band Inlet (compressor/cold side) Ø 102mm (4") Outlet (compressor/cold side) Ø 65mm (2.5") Compressor major diameter Ø 84 mm since there's only a $30 difference between the two(and this one says brand new as the other one doesn't but it might be new(doubit it though), it doesn't say used) i'm considering either but i dont' know how to "read" the specs to know if its optimized for a bigger or smaller motor. Quote
RobertISaar Posted May 27, 2007 Author Report Posted May 27, 2007 normally i'd have a response within 3 minutes... i'll try giving more information going to be for the motor in my sig... going to rebuild the top when i pull it to install the 282(if i can find them cheap enough, forged pistons, if not hypertruec(?)). i'll be doing a P&P on the heads as well as the LIM and UIM and i might try lowering the compression a little bit by removing material in the combustion chambers. it'll eventually move over to a 3400 or a 3500/3900 if they ever get cheap enough for me to consider them a deal. if this goes through the wet shot nitrous idea is going out the window(don't need it with a decent turbo) Quote
IRONDOG442 Posted May 27, 2007 Report Posted May 27, 2007 I know zero about turbochargers, Sorry Quote
RobertISaar Posted May 27, 2007 Author Report Posted May 27, 2007 I know zero about turbochargers, Sorry apparently neither does anybody else thats browsing the forum today... i'll have to try the 60degree forum Quote
Roadzombie Posted May 27, 2007 Report Posted May 27, 2007 Not sure about the T70, but the T3/T04 might be a bit small. The T3/T04 was the upgrade of choice when I had my 2.2L I4 Probe GT...so may be a bit on the small side for a 3.1L V6. Not saying it wouldn't work, but ya may want to go with something a little bigger for more bang for your buck. Quote
RobertISaar Posted May 27, 2007 Author Report Posted May 27, 2007 yeah but how high did that probe turn its motor to. btw i could have bought a 89 probe gt with turbo 2.2 and 5 speed for 300...all it needed was a radiator :smiley that smacks himself on the forehead: Quote
kuntzie Posted May 27, 2007 Report Posted May 27, 2007 just get a gt2871r/ gt3076r and call it a day the 1st turbo is too small, the 2nd one is too big Quote
AWeb80 Posted May 28, 2007 Report Posted May 28, 2007 i've seen in person, 3 ebay turbos split the housings becuase the shafts aren't balanced or something like that.....? Quote
digitaloutsider Posted May 28, 2007 Report Posted May 28, 2007 eBay turbochargers that sound too good to be true (read: price) are pieces of shit. Trust me. Quote
