19Cutlass94 Posted May 27, 2007 Report Posted May 27, 2007 Ok, so I had to put a new condensor in the car because the other one, well a nice screw went through it. So now the system is completely empty. What wires on the compressor do I need to jump so that I can engage the compressor and fill the system? I believe there are 3 wires, not sure of the color off the top of my head. Any imput is great Thanks --Jay Quote
White93z34 Posted May 27, 2007 Report Posted May 27, 2007 you shouldn't have to junpstart any of them. you should be able to fill the system and when the compressor sees adequate pressure, it will engage itself. Quote
Dark Ride Posted May 27, 2007 Report Posted May 27, 2007 you shouldn't have to junpstart any of them. you should be able to fill the system and when the compressor sees adequate pressure, it will engage itself. yup, I wouldn't recommend jumping any wires, or you might be replacing the compressor next. Quote
NVMY03GT Posted May 27, 2007 Report Posted May 27, 2007 I think he will have to bypass the low pressure switch. I had this problem on a Saturn, the compressor won't engage until it has SOME pressure and you can't get pressure until Freon enters the system Quote
ron350 Posted May 27, 2007 Report Posted May 27, 2007 I think a 94 uses the same three wire transducer as my 96 Regal uses. You are not supposed to be able to jump the transducer and make the compressor clutch engage. Once the transducer sees around 30psi in the system it will tell the PCM to engage the AC clutch relay. The safest way to engage the AC clutch is to pull the cover off the relay and push the contacts together. Quote
Pontiac6KSTEAWD Posted May 27, 2007 Report Posted May 27, 2007 Thats correct, you need to make sure to have your system vacumed out, and then filling from the low side port, adding some R134a. About 1 can into it, your compressor will kick on. Should take about 2.5 cams to fill in total.. Quote
19Cutlass94 Posted May 27, 2007 Author Report Posted May 27, 2007 I know its only a 2lb system. So 2 cans and some pag oil will be more than enough. But I know there needs to be a certain amount before the compressor will engage. my dad seems to think that you need to engage the compressor, but if it needs to be vaccumed, then I *should* be able to hook that up, start with the freon and the compressor should engage correct? Quote
rockfangd Posted May 27, 2007 Report Posted May 27, 2007 yeah i had to do a ford contour yesterday and the only way i could get the compressor to kick on was to bypass the pressure switch until it had pressure. Works every time Quote
R Dubya Posted May 27, 2007 Report Posted May 27, 2007 most GM vehicles will just accept the refrigerant. turn on the A/C system to max and then blast the fan, then connect to the low side port. it willl automatically depressurize the can and enter the system to a certain point, then the compressor will engage and empty the source. Quote
Crazy K Posted May 28, 2007 Report Posted May 28, 2007 manually operating the relay FTW. doing so bypasses all the safty crap. bypassing the pressure sensor will not work, as it is lookin for a specific reading... You will discover that the Ecm actually knows the exact pressure of the ac system in it's data stream output. Quote
19Cutlass94 Posted May 28, 2007 Author Report Posted May 28, 2007 most GM vehicles will just accept the refrigerant. turn on the A/C system to max and then blast the fan, then connect to the low side port. it willl automatically depressurize the can and enter the system to a certain point, then the compressor will engage and empty the source. So then your basically saying just fill it up the way I normally would? As if it was just low on freon correct? Quote
R Dubya Posted May 28, 2007 Report Posted May 28, 2007 correct, but depending on how old it is, you may just want to have the system vacuumed out and then have new pag oil and refrigerant installed, or do it yourself after you have it vac'd out. Quote
GnatGoSplat Posted June 1, 2007 Report Posted June 1, 2007 Anytime the system is opened, it's mandatory to have it vacuumed out if you want it to work right. Quote
Crazy K Posted June 1, 2007 Report Posted June 1, 2007 i need to get a vac pump. my solution for not having a vac pump was to simply vent the first can of r-134 back out the high port. then totally recharging the system... but that is ghetto. Quote
GnatGoSplat Posted June 1, 2007 Report Posted June 1, 2007 The reason for vacuuming the system is to remove any residual moisture, would venting a can of refrigerant out the high port actually accomplish this? Oh yeah, it's illegal to vent refrigerant, even 134A! Quote
19Cutlass94 Posted June 2, 2007 Author Report Posted June 2, 2007 Thats not a problem to get it vaccumed out. I believe we have all that stuff here. Just need to go get some freon and pag oil. Thanks Quote
