map light wiring
w-bodys_are_the_best
I kept my map light rear view mirror from my 94 CS along with most of the interior from it when I scrapped it. I just fixed my windows in my 90 Z24 cav, and today took the headliner out because I need to fix it.
I know this isn't a W, but I need to know the wiring for the mirror, and it's from a W. I do know that the 94 was different from the 92 CS parts car I had at one time, because I was going to swap it with the shattered one in my 94, and ended up actually just swapping the mirror glass and snapping the mirror back together because the plug was different. I forgot to grab the wiring pigtail from the 94, but I'll go grab one from the J/Y this weekend sometime. The cav had only 2 wires to the dome light, which I am going to splice into, one was white and one was orange and white. I'm assuming the cav only has the switched power and ground, not sure though. :lol: I wish I knew where my test light was. I did a search for mirror wiring and found an old post that said:
pink = + always hot
black = - ground
yellow = + hot with door open/int. lights on
Did the wiring colors change at all for the different style mirrors, or just the plug?
mirror:
Z24 WIRES:
