L67LuminaEuro Posted May 18, 2007 Report Posted May 18, 2007 I was wondering if i put a floor shifter in my Euro sedan can i run an " extension harness", if you will, from the column neutral switch to the shifter itself or how does that work. As i type i relized that the switch is on the tranny. I'm an old car guy and thry used to be on the column. What would it take to swap in a shifter from a Z or 3.4 sedan. Quote
digitaloutsider Posted May 18, 2007 Report Posted May 18, 2007 Wait.. what are you wanting to do? Quote
Crazy K Posted May 18, 2007 Report Posted May 18, 2007 you need: the longer shift cable from the shifter to the transmission the shifter mechanism with the nuts and snap into the floor retainers for the shifter the center console and associated mounting hardware. bucket front seats. steering column, with ignition switch WITH shift lock cable. block off plate that covers the former location of the shift indicator. Quote
