synistershadows Posted May 16, 2007 Report Share Posted May 16, 2007 alright heres my problem i have NO rear signal lights at all! I have the tail lights and brake lights the front signals work both left right and hazzards all work on the front but nothing on the back I have already replaced the signal switch and replaced all the bulbs on the car and checked all the fuses and grounds. im at a loss i have no clue whats wrong i was looking at the conector in the trunk of my car (right hand side by the antenna) where the fuse is. and it seems theres a yellow wire eathier cut or broken off but i cant find where it connects up to? could that be my problem? Quote Link to comment Share on other sites More sharing options...
1990lumina Posted May 16, 2007 Report Share Posted May 16, 2007 Sounds like a wiring issue to me, but it's wierd both sides aren't working. I don't want to confuse myself, but that yellow wire doesn't have anything to do with the keyless entry box?? (The ground wire to make it learn new remotes)?? Quote Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted May 16, 2007 Report Share Posted May 16, 2007 I think that its the brake light switch that gone bad. I cant remember if it goes from the turn signal wiring to the brake wiring, or the brake wiring to the turn signal wiring. I cant remember off the top of my head. Maybe someone else can chime in. Quote Link to comment Share on other sites More sharing options...
synistershadows Posted May 16, 2007 Author Report Share Posted May 16, 2007 Sounds like a wiring issue to me, but it's wierd both sides aren't working. I don't want to confuse myself, but that yellow wire doesn't have anything to do with the keyless entry box?? (The ground wire to make it learn new remotes)?? i dont think its the keyless entry thing cuz i dont have keyless entry. i know that they could have come with it but i just dont have it. plus its like right by the radio antenna just behind the right rear taillight. and i know that the fuse there works with the lights cuz i took it out and on side of my lights didnt light up when i steped on the brakes with the fuse out. but i just dont know where that wire goes Quote Link to comment Share on other sites More sharing options...
synistershadows Posted May 17, 2007 Author Report Share Posted May 17, 2007 so this the connector im talking about [attachment deleted by admin] Removed to free up storage space. Quote Link to comment Share on other sites More sharing options...
1990lumina Posted May 17, 2007 Report Share Posted May 17, 2007 I really don't think that's a factory connection/fuse holder..but I could be wrong. Quote Link to comment Share on other sites More sharing options...
synistershadows Posted May 17, 2007 Author Report Share Posted May 17, 2007 i've seen them on a few j/y cars but i dunno that one wire i just dont know what to do i need thoes lights to work im outa a car untill they do Quote Link to comment Share on other sites More sharing options...
synistershadows Posted May 18, 2007 Author Report Share Posted May 18, 2007 anyone who can help me out? Quote Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted May 18, 2007 Report Share Posted May 18, 2007 I think that its the brake light switch that gone bad. I cant remember if it goes from the turn signal wiring to the brake wiring, or the brake wiring to the turn signal wiring. I cant remember off the top of my head. Maybe someone else can chime in. Must have me on ignore or something, but just in case you just missed it.... Quote Link to comment Share on other sites More sharing options...
synistershadows Posted May 29, 2007 Author Report Share Posted May 29, 2007 my break lights work though along with my tail lights? Quote Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted May 29, 2007 Report Share Posted May 29, 2007 They may work, but one of them has to interupt the other for the function to work. So that leads me to believe that the Brake light switch has gone out, or, the wiring in the column for the turn signal is bad.. Quote Link to comment Share on other sites More sharing options...
synistershadows Posted May 29, 2007 Author Report Share Posted May 29, 2007 in the pic i took is where it switches over i think due to the fact that when i took out the fuse thats there one of my brake lights worked and one didn't so i dunno if that could be where the problem is or not?? like i said theres that one wire that looks cut or broken but i cant find where it goes to? Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted May 29, 2007 Report Share Posted May 29, 2007 stoplight switch is $10. just put it in and see if it works. If not return it! Quote Link to comment Share on other sites More sharing options...
synistershadows Posted May 30, 2007 Author Report Share Posted May 30, 2007 know where i can get one? and how hard it is to put in ?? as well as where it is? Quote Link to comment Share on other sites More sharing options...
synistershadows Posted June 1, 2007 Author Report Share Posted June 1, 2007 please help!! i cant drive my car untill this is fixed my back signals dont work at all be it hazzard or left/right!! the tail lights and Brake lights WORK but the signals dont!! Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted June 2, 2007 Report Share Posted June 2, 2007 You can get it at NAPA. As far as where it is, Im not sure. Someone else can chime in though. Quote Link to comment Share on other sites More sharing options...
synistershadows Posted June 5, 2007 Author Report Share Posted June 5, 2007 help anyone?? Quote Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted June 5, 2007 Report Share Posted June 5, 2007 Have you replaced the brake switch yet? Quote Link to comment Share on other sites More sharing options...
