mdelorie Posted June 23, 2003 Report Posted June 23, 2003 Aside from regular maintenance items, (filters, plugs, tires, brakes etc.) What's gone on everyone's car? In the two years I've owned it I've replaced: alternator, ball joints, shocks, heater line, throttle body coolant line, water pump, coolant sensor and fitting, front seal on my power steering pump. Basically, what should I look out for next? Quote
Panopticon Posted June 23, 2003 Report Posted June 23, 2003 POWER MASTER III it just broke and its hard to find a working one. -Suspention (shocks & struts) -Alternator *the 2 above were a result of a dodge durango smoking the front pgr side* -Drivers side outter door handle -*NEW* leak in the rear windsheild, headliner ruined. -Power door locks (locks but not unlock) -Passenger side window goes down but not up -A/C Quote
gimp19 Posted June 24, 2003 Report Posted June 24, 2003 Coolant snesors, Spring plate, A/C, Brakes, Tie rod end, CV joints/boots thats all the stuff thats gone in my car in the three years I've owned it. Not too bad considering its 16 years old, and most of it was caused by the salty winters. Quote
Slade901 Posted June 24, 2003 Report Posted June 24, 2003 Oxygen sensor and Throttle Position Sensor. Quote
Intlcutlass Posted June 25, 2003 Report Posted June 25, 2003 Map sensor Fuel pressure regulator front hub bearings injectors radiator cruise control cd player lumbar seats struts water pump a/c (still broken) Muffler radio power ant (still broken) I think thats it....... Quote
Panopticon Posted June 25, 2003 Report Posted June 25, 2003 POWER MASTER III it just broke and its hard to find a working one. -Suspention (shocks & struts) -Alternator *the 2 above were a result of a dodge durango smoking the front pgr side* -Drivers side outter door handle -*NEW* leak in the rear windsheild, headliner ruined. -Power door locks (locks but not unlock) -Passenger side window goes down but not up -A/C ohya forgot to mention...my 86 accord with nearly the same miles is rusted but has never had an engine/drivetrain problem..... :shock: Quote
92turboLE Posted June 25, 2003 Report Posted June 25, 2003 do you really wanna hear what has gone wrong on mine??? ok, well imm be typing this for a while... ENJOY! Car: 1992 Pontiac Grand Prix Sedan Problems: how many Part that times: Broke: 6 alternators (due to large sterio system) 2 starters 1 starter cylenoid 2 water pumps 1 tensioner pulley 4 serpentine belts 1 4T60 Transmission 1 sub frame dropped out - both CV Shafts, - right side tie rod - both struts - new downpipe - steering shaft - break master cylinder 2 right side front caliper fell off 2 right side front caliper cracked (unrelated from falling off) 1 right side rear caliper cracked 1 Monoleaf split 1 drivers inside door handle broke 1 right rear power window switch 1 horn switch 1 both power mirrors 1 wheel fell off while driving 1 blinker relay (steering colum started smoking) 1 blinker switch 1 rear bumper fell off (due to drift busting in the snow) im thinkin there was more, but that is the jist of it.... now she runs like new, still with 221K original miles on the engine and 60 on the new tranny. and the funny thing is the only thing on the list that cost me more then 100 bux was the tranny.... nearly everything else i was able to fix for undewr 50... hehehehe - Justin Quote
phantomFE3 Posted June 25, 2003 Report Posted June 25, 2003 so far: Digital dash Windshielt wiper/cruise control/blinker knob handle for hood release oil pump drive seal i think my oil pump is getting weak power antenna ^those are the things that i havent fixed^ drivers side door handle original radio ground effects broken air box windshield wipers ^those are some of the things that broke that i have fixed or am currently fixing^ i am sure there is more, i just cant think of any right now Quote
cutlassdude96 Posted June 26, 2003 Report Posted June 26, 2003 stuff thats been fix Intake gaskets plugs and wires new rear rotors and pads new front pads new front end (hit a telephone) stuff thats needs to be fix front and rear suspension Alt. going out Quote
