backyardmechanic Posted May 14, 2007 Report Posted May 14, 2007 I went to replace a rear view mirror on my car and I screw up and put that metal piece that goes on the window on backwards and of course the mirror doesn't stay on. How do I remove it? That adhesive really has got that stuck to the windshield. I'm afraid if I pound on it the windshield will crack. Thanks, Gary Quote
kuwaitliberation Posted May 15, 2007 Report Posted May 15, 2007 Either that, or mount the mirror, anyway and have my 7 year old hang on the mirror. That gets it off, quick! Quote
19Cutlass94 Posted May 15, 2007 Report Posted May 15, 2007 Yes, if you do pound on it, it will crack I know. Get some heat like a heat gun, thatll work Quote
Psych0matt Posted May 15, 2007 Report Posted May 15, 2007 just pull it off. the window is bent the other way, it would take an awful lot to crack it from the inside pulling in Quote
19Cutlass94 Posted May 15, 2007 Report Posted May 15, 2007 actually, the windshield will crack there easier than you think. Quote
Psych0matt Posted May 15, 2007 Report Posted May 15, 2007 I just ripped mine right off, then used a razor blade to clean the rest of the old glue off Quote
19Cutlass94 Posted May 15, 2007 Report Posted May 15, 2007 you got it easy then. I tried to take one off, and ended up break the windshield, and there was still glass on the metal piece after it was off! Quote
GtipGary Posted May 15, 2007 Report Posted May 15, 2007 I used laquer thinner ... i had a rag and squirted the thinner on there while soaking up the excess with a rag... i would squirt it then try to wiggle it after a few times it started to wiggle then it came off... ive also heard that 3m adhesive remover works the same Quote
Q-Ball Posted May 15, 2007 Report Posted May 15, 2007 Let your car bake in the sun for a good few hours. I've seen a few people when they get back in the cars that the mirror fell off on its own. But after baking it, the glue will be in a type of jelly form and should be able to pulll it off. But heat is the key. Quote
backyardmechanic Posted May 15, 2007 Author Report Posted May 15, 2007 Thanks for all the replies. This is great! I'll hang the 7 year from the mirror as a last resort though! Quote
rockfangd Posted May 15, 2007 Report Posted May 15, 2007 yeah just yank it off. works every time with no gaurantees lolol Quote
5speedz34 Posted May 16, 2007 Report Posted May 16, 2007 Let your car bake in the sun for a good few hours. I've seen a few people when they get back in the cars that the mirror fell off on its own. But after baking it, the glue will be in a type of jelly form and should be able to pulll it off. But heat is the key. x2. Heat is the way to go. Quote
