intern8tion9l Posted May 14, 2007 Report Posted May 14, 2007 well everything was smooth sailing on the cutlass until i tried to put the rear ss brake lines on. i cranked the bitches as hard as i possibly could and they are still leaking brake fluid like a whore. anyone else using the old style ones having this problem by any chance?? Quote
intern8tion9l Posted May 14, 2007 Author Report Posted May 14, 2007 i'll take that as a negative Quote
19Cutlass94 Posted May 15, 2007 Report Posted May 15, 2007 If I knew how the older style lines were designed, I could help ya out, but I dont. Did you try the other side yet? If you cant get that to work, wait and bring the car up here and well work on it to see if we can get it to work. Quote
pwmin Posted May 15, 2007 Report Posted May 15, 2007 ya, can you get some pix or something? im not sure why if you can put newer brakes on an older car you cant use the older style lines. Quote
GutlessSupreme Posted May 15, 2007 Report Posted May 15, 2007 you're using new crush washers, right? I guess first I should ask which end is leaking Quote
mfewtrail Posted May 15, 2007 Report Posted May 15, 2007 Are they flared like the original lines or not? "Invasion1" had to reflare the goodridge lines he put on his Cutty(don't remember what year it was or which goodridge kit he bought though..) Quote
FordBoy Posted May 15, 2007 Report Posted May 15, 2007 you have the copper washers there right? if so try to replace them and see what happens they are so cheap Quote
GutlessSupreme Posted May 15, 2007 Report Posted May 15, 2007 Are they flared like the original lines or not? "Invasion1" had to reflare the goodridge lines he put on his Cutty(don't remember what year it was or which goodridge kit he bought though..) yea that was my second thought.. might be the wrong flare. Quote
GOT2B GM Posted May 16, 2007 Report Posted May 16, 2007 I bet its a single flare instead of the factory double flare Quote
GutlessSupreme Posted May 16, 2007 Report Posted May 16, 2007 I bet its a single flare instead of the factory double flare I just got my g-stop lines but I haven't really looked at them.. but I'm pretty sure single flare is very unsafe for brake lines so I wouldn't think so. Quote
intern8tion9l Posted May 18, 2007 Author Report Posted May 18, 2007 sorry its been so long. i gotta look at them again, i was talking to a friend of mine and he also said it sounds like a flare problem. i'll keep you guys posted Quote
pwmin Posted May 22, 2007 Report Posted May 22, 2007 not to bug, but any update? i need to order some lines and i wanna make sure i order the right ones. my rubber lines are shot on the outside, not leaking yet, but they will soon. Quote
Bake82 Posted May 22, 2007 Report Posted May 22, 2007 I now own Davis' car. If it would help I could take some close up pictures of the goodridge lines and the hard metal lines on the car to see if they're different than yours. His doesn't not have ABS. Quote
pwmin Posted May 22, 2007 Report Posted May 22, 2007 that would be great. my car doesnt have abs either. what style lines does he have? im assuming it has the 94+ upgrade? Quote
pwmin Posted May 22, 2007 Report Posted May 22, 2007 im just going to order the 94+ ones (12237) since im going to have all 94+ brakes. so, what is the diff between 12236 and 12237, are the 7's just longer? Quote
Bake82 Posted May 22, 2007 Report Posted May 22, 2007 that would be great. my car doesnt have abs either. what style lines does he have? im assuming it has the 94+ upgrade? The car does not have the 94 upgrade. Just brand new rear 88-93 calipers Quote
intern8tion9l Posted May 23, 2007 Author Report Posted May 23, 2007 no update guys, i left the stock lines on the back while i'm working on other things(major turbo issues). bake you own davis's white cutlass now?? Quote
Bake82 Posted May 23, 2007 Report Posted May 23, 2007 no update guys, i left the stock lines on the back while i'm working on other things(major turbo issues). bake you own davis's white cutlass now?? Yup...it's up on jack stands with front/rear suspension completely out of the car....getting ready to go into my own 88 Cutlass. Unfortunetly his car is being dismantled and the parts being used for my own 88 cutlass turbo 5 spd project! Quote
intern8tion9l Posted May 24, 2007 Author Report Posted May 24, 2007 let me know if you need help with info or anything with the build, ours will be like identical. thats friggin sweet! too bad about dave's car though. and too bad i'm posting like almost the same crap to you here and on tgpforums. haha Quote
