whip Posted May 12, 2007 Report Posted May 12, 2007 I have a 1991 Gp that had an idle problem. Everything I read pointed to change out the intake gaskets. I have did so and changed out the IAC valve also. I have checked for vaccuum leaks also. This car still will not idle down below 2000 rpm. Any ideas would be helpful. Thanks. Quote
Q-Ball Posted May 12, 2007 Report Posted May 12, 2007 How long has this been going on for? How many km or miles on your car? Quote
Crazy K Posted May 12, 2007 Report Posted May 12, 2007 ditto on above. try... unplugging the TPS sensor and seeing what the car does. Quote
whip Posted May 12, 2007 Author Report Posted May 12, 2007 The car has had a motor change done to it. Motor is of 94-66 vintage. Mileage unknown but runs good. It has a hyper chip in it. Quote
Andrew Posted May 12, 2007 Report Posted May 12, 2007 has this only happened since you swapped motors? try the TPS that ken suggested. Quote
ns87 Posted May 12, 2007 Report Posted May 12, 2007 Also check the car's coolant temperature sensor (not the one for the gauge). If its reading too low, it'll force a high idle Quote
whip Posted May 12, 2007 Author Report Posted May 12, 2007 Hey guys! Aprreciated the advice. I changed the cts sensor , but it still idles up[ to 25000 rpm right away. Also took the tps out and reinstalled it ,but it diddn't change anything. I have did alot of work on my cars on my own, but this headache is driving me insane!!! I have also rechecked the throttle linkage and TB for binding and there is none. Keep giving me ideas!!!!!!!!!! Thanks. Quote
