how do i remove fuel rail/ injectors on 3100???
Well this is really my first fuel injected internal engine work i've ever done. I took out the two middle bolts holding it on and it still isn't coming out it feels loose but i can't get it to come out.. Do i just pull untill it does or what??
yupp, the injectors will pop out. But make sure you have the o-ring thats on the end of them. Pop the fuel rail with the injectors straight up, but just be careful.
i'd spray some lubricant around each injector and then give them a good tug. they should come right out. I would suggest getting new o-rings. If they still look good and feel tight you might be able to get by by lightly oiling them with motor oil and re-installing.
wiggle it around as you pull up sometimes a long flat head screwdriver has to be used too, I pry up on the injectors sometimes to make em pop.
oh...
DID YOU REMOVE THE BOLT THAT LOCKS THE HOSES DOWN TOO?
Yeah i got all three bolts. I just never took injectors out before and I didn't want to mess anything up. Thanks guys i will probably post again for more help..
