282 speed sensor
anyone have a pic of it? Something's broken on mine and I don't know if the sensor's connector itself is broken, or if the connector on the wiring half is. I can't seem to remove the sensor from the tranny either. It will rotate if I twist it with pliers with the hold-down plate off, but I can't seem to get it to come up and out.
dude i couldnt even get mine to rotate :eek:. this pics was off my spare trans so hope it helps
dude i couldnt even get mine to rotate :eek:.[/img]
And that is allways a good thing, because it is so close to the reluctor wheel, that it would have broken if you rotated it. Mine is seized into the housing too and had a bunch of magnetically attached particles on it but if you need to pull it out you have to open the trans and push it out from inside, unless you are planning on breaking it and replacing it. Advance auto parts has them for $57 in the store and $42 online.
