GPdriver1986 Posted June 22, 2003 Report Posted June 22, 2003 Hey guys, I just installed a used caliper in the back on the drivers side because I broke the old one. But I think I didn't tighten the bleeder valve enough because its leaking fluid. How tight should it be?and also how to tight should the screw for the rubber brake line be? Quote
NOHC_WBody Posted June 23, 2003 Report Posted June 23, 2003 It's probably the crush washer below the fitting going into the caliper. They're made to seal once. When the hose fitting is tightened down, it crushes it to the caliper with serrations on the bottom of the fitting, sealing it. It's damn near impossible to line them up again. Take the bleeder valve off, and put some thread sealant, or teflon tape on it, being careful to not get any below the threads. Quote
Slade901 Posted June 23, 2003 Report Posted June 23, 2003 Do not use a regular wrench. I think a 10mm wrench work but don't be tempted to use that kind of wrench otherwise you will strip the bleeder screw. Use the right tool which is brake bleeder wrench available at local autoparts store. When you tight the bleeder screw, it should be hand tight. Where is it leaking? around the bleeder screw threads or around the bleeder screw tip? You might want to use a teflon tape around the bleeder screw threads and thread it back in the caliper. Quote
GPdriver1986 Posted June 23, 2003 Author Report Posted June 23, 2003 Thanks for the help guys I think its leaking around the thread. I have some tefon tape so that should help. Quote
GPdriver1986 Posted June 23, 2003 Author Report Posted June 23, 2003 and if its leaking from the crush washer then what should I do? Quote
