THESE P #'S ARE FOR FE3 ONLY
BUT THE INSTALL WILL BE THE SAME FOR OTHERS AS WELL.
they are Energy suspension P#'s
Front inner: 9.5173
Front outer: 9.5159
The bar is 34mm and the bushing is 35mm on the inners and the bar is 22mm and the bushigns are 23mm on the outers...I got the 1mm bigger ones because they are the only size close enough that were greasabel.....on the test ride, there were no problems and uppon installation, everything looked fine.
I'm very impressed w/ the quality of the bushings and the mounts. Well worth the ~$32 total that it cost...free shipping from
http://www.energysuspensionparts.com/
I had an extra bar so i got it powdercoated grey....I now have my stock 34mm bar FOR SALE if anyone wants it. PM me.
and yes, you HAVE to lower the rear subframe to get the bar out....not that hard to do...just takes an extra jack to hold the subframe from falling to the ground.
I noticed an imediate difference in steering response and the car wanting to turn in to a turn and not body roll...well worth the investment.
So what is all involved in installing this?
This took me about 2 hrs...from pulling the car in to pulling it back out...I took my time...
for a non 34mm bar car...which yours is
jack up th front end, take both wheels off.....then loosen all the mounts..inner and outter
put a jack under the rear subframe, take out both subframe bolts 18mm wrench needed.
use the jack to lower the subrame....take your bar out, put 34mm in, (notice: the 34mm bar has the ends of the bar turned down slightly....put the ends that are turned town facing the ground)
pre lube the poly mounts, put them on the bar, put U-clamps on and tighten all bolts, tighten subframe back up..and have fun.
Hmm..want to sell your old bar to me for cheap?
yeah...i picked up the one that i got PC'd for $20 at a JY...you want me to PC your bar?
i can do $40 shipped to you if you want it pc'd.
No..I don't want it powdercoated, nobody will ever see it.
I'll take this to PM's!
Matt I thought you already had the 34mm bar? Not to mention Adam's stock bar might be smaller.
its not...it is 34mm....i measured it.
So you replaced it with a powdercoated one thats it?
i got another 34mm bar because i wanted to PC it...i then swapped 34mm bars....and put the ES bushings in.
all B4U GP's got 34mm front bars...
looks familiar! PCing looks good
nice job! And I read the bold print this time Adam.......
sweet.
  • 8 months later...
talking to Tom....he wanted info on it
why worry about it...you just got a free post out of the deal.
:willynilly:
Hows it holding up? I went the maintenance free/smoother ride route and got the blue hardass rubber bushings from MOOG. 's right!
great.
I love them.
NO loss in ride quality.......cars need these from the factory.
I've had mine since fall of 06 and they are holdin up just fine over here. :burnout:
I need to get these poly bushings for me. Adam, where did you get your front sway bar?
It was an extra one i got cheap from a yard
I still have an extra one....you want it?
