briandors Posted June 19, 2003 Report Posted June 19, 2003 I'm getting some noise while turning the steering wheel, and memory steer, can someone supply a tutorial on replacing the front strut bearing plates? Thanks, Brian Quote
Panopticon Posted June 19, 2003 Report Posted June 19, 2003 i have the same problem memory steer? like when you turn it it will kinda almost stay turned? Quote
briandors Posted June 19, 2003 Author Report Posted June 19, 2003 Although it could be steering system related, usually it's the bearings the struts swivel on. Brian Quote
patgizz Posted June 19, 2003 Report Posted June 19, 2003 i dont know how, just wanted to say hi, i live near cleveland Quote
Bake82 Posted June 19, 2003 Report Posted June 19, 2003 yah i don' know how either, but my cutty had these replaced today as a matter of fact, 100 bucks EACH cdn, and then they need to do an alignment aswell, + labor, so yah I'm down about 4-500 bucks! But I'd like to know how hard they are to do, to know how much i got screwed over...other than the alignment thing! if you try this tho, good LUCK! Quote
ctx46 Posted June 20, 2003 Report Posted June 20, 2003 k... here we go.... remove wheel/caliper/rotor then pull the axle nut off.. remove ball joint and tie rod remove upper strut mount bolts and the strut assembly will be in yur hand... now.. U NEED a good spring compressor for this!! if U dont tak it in....!!! U will get hurt if U dont have a secure one.. compress the spring and remove the top strut bolt (24 mm) the strut will drop out of the mount, then U simply pull off the bearing plate and put in a new one in its place. U have to compress and remove the strut cause the strut turns in the middle, not @ the top like most cars do... reverse these instruction to put em back in... its pretty straight forward... this is also a good time to do the ball joints, struts (since U can do em with a pip wrench rather thatn having to Use the tool) and the tie rods... that is if there all OEM... there not that bad... just time consuming, and U NEED a spring compressor... PM me if U have any questions.. later joe Quote
briandors Posted June 20, 2003 Author Report Posted June 20, 2003 Thanks Joe, Seems like a big job, and if you don't compress the spring right it could end up being deadly. I'll leave this one to a garage. Brian Quote
Slade901 Posted June 20, 2003 Report Posted June 20, 2003 Thanks Joe,Seems like a big job, and if you don't compress the spring right it could end up being deadly. I'll leave this one to a garage. Brian Do you have another car you can use while the other car is getting fixed? If I were you, I'll try to tackle it myself and learn along the way. I got a 2 sets of spring compressor just in case. One important thing when dealing with removal of struts/springs is to mark their orientation with a white markter so they will be aligned back when you install them. At first it was hard but then after a while it was pretty straight forward. Then again.. if you don't feel confident then it's better to have a shop do it for you. Quote
