radio install kit??
looked in the Scosche book and they said they dont make a 98-91 dash kit for the grand prix, is there something else i can use?
will the 92-96 kit work? and is the radio mount and everything the same on 90-96?
I don't see why it wouldn't work.. The one I bought from Wal-Mart worked just fine in my Cutlass.
92-93 is identical to 90-91, so I'm not sure what they're getting at.
The only issue I see with this is if you have a radio setup like or similar to this one:
If this is the case, you need to go to the junkyard and grab the radio surround piece(s) to make your's look more like this:
If your radio already looks like this, the GM (IIRC) 78 and up kit will work fine for you.. The same kit will work if you need to swap the radio opening, but the swap is just an extra step. AFAIK, the wiring is all the same.. Make sure you get the 88+ GM WIring harness, and the GM Mini Barb antenna adapter!
cool thankyou i have the regular radio so it should be easy then thanks again
You know, I wish I had an 88-93 GP interior.. THat cubby off to the right of the radio would be a perfect iPod dock location!
