Quote
BMR adjustable lateral arms replace the factory 3/4" diameter arm with a heavy duty, 1.25" diameter tubular unit. The large 3/4" adjuster allows "on-car" adjustment in an accessible location. The OE rear mount lateral bars are not adjustable from the factory but the BMR replacements provide additional caster adjustment that was not possible with a fixed length arm. The BMR tubular trailing arms replace the factory stamped, u-shaped trailing arm with a 1.5" diameter tubular upgrade. All arms come standard with low deflection, fluted polyurethane bushings equipped with grease fittings. Available in Black Hammertone or red powdercoat.
Part #TCA011 Tubular trailing arms $129.95 pr
Part #TCA012 Adjustable Lateral Arms - forward mount $209.95 pr
Part #TCA013 Adjustable Lateral Arms - rearward mount $209.95 pr
Kit #WPKG001 All of the above $499.95 set
How will these allow caster adjustment? Is this a typo and they really mean camber? I don't see any way that you could adjust caster with lateral links. And the way it looks to me, the factory lateral links are adjustable.
Correct me if I'm wrong though, I am tired
The OEM rear links don't have any adjustment mechanism. These ones have both front and rear adjustment, allowing a caster adjustment. The overall adjustment mechanism is far superior to the factory gen 1 method of a slotted upper hole on the crossmember.
Edit: Wait... I think my definition of caster is confused.... so... how DO these allow for a caster adjustment?
