Serious "squealing" noise after cv half-shaft/ball joint replacement.
Hey guys, its been a long time since I last posted. The old prix has around 188,000 miles on it now, but is still running well.
I had been getting alot of bumping and popping noises coming from the passenger front suspension. So far I have replaced the struts on warrantee, the lower ball joint and the cv shaft as i ripped it apart getting the ball joint off. :mad: anyway now all that is back together and thier is no more popping or thunks. The proplem is I now have an high pitched squeel happenning during normal and high excelleration. It sounds like the warning squeekers on a brake pad but the pads on the front are brand new and are clear of the rotor.
Any ideas what could be making such a noise? I've taken it apart three times now and there is nothing that isn't tight and nothing seems to have any rubbing or wear marks on it.
Thanks guys.
Bump :confused:
need my car fixed by tomarrow for work. Any ideas?
Thnx
