slick Posted April 11, 2007 Report Posted April 11, 2007 This is for the normal GM plug, usually found in 88+ GM vehicles. This doesn't apply to the GM 32 pin, but I will post that info tomorrow. These wire colors are pretty much universal through the GM vehicles. BE SURE TO TEST YOUR WIRES. W-BODY.COM NOR I ARE RESPONSIBLE IF YOU FRY SOMETHING. Orange = 12v Constant/Battery Yellow = 12v Switched/ACC Black = Ground Gray = dimmer ground Brown = Parking lights Tan = Left front + Gray = Left front - Lt. Green = Right front + Dk. Green = Right front - Brown = Left rear + Yellow = Left rear - Dk. Blue = Right rear + Lt. Blue = Right rear - If you have the Monsoon or Bose system, you will need to tap into the amp turn on lead. The harness's that you buy do not have these leads, so you will need to tap behind the plug. Generally, the wire colors for the amp turn on lead are Pink or Dark Green. You can test with an inline fuse holder and wire. Connect one end to the amp turn on lead on your aftermarket deck (99% of the time blue or blue/white), and strip back a bit of the Pink or Green wire, and connect this end to it. If you hear sound, your in luck. No sound, keep checking. But, be sure to use the inline fuse holder. I generally use a 5 amp fuse for testing purposes, and replace with a 10 amp fuse once I have found the correct wire. Heres a picture for an example: Quote
FordBoy Posted May 22, 2007 Report Posted May 22, 2007 for the dimmer ground and the parking lights: the dimmer i just have to ground the parking lights to a positive i also have a pink wire under there you know what that one is for? Quote
slick Posted May 22, 2007 Author Report Posted May 22, 2007 for the dimmer ground and the parking lights: the dimmer i just have to ground the parking lights to a positive i also have a pink wire under there you know what that one is for? the wire colors for the amp turn on lead are Pink or Dark Green. You can test with an inline fuse holder and wire. Though it may not always be the case, you need to test. They could be other data wires as well(SWC's, etc...). Quote
FordBoy Posted May 22, 2007 Report Posted May 22, 2007 ok sry these were qts i forgot the ? for the dimmer ground and the parking lights: the dimmer i just have to ground ? the parking lights to a positive? i also have a pink wire under there you know what that one is for? Quote
slick Posted May 22, 2007 Author Report Posted May 22, 2007 Again, it's up to you to test. If for some reason your electrical system is screwed, it could be the opposite. Anyways, why cut the connector off anyways. Causes more trouble than what it's worth. Quote
FordBoy Posted May 23, 2007 Report Posted May 23, 2007 for the dimmer ground and the parking lights: the dimmer i just have to ground ? the parking lights to a positive? Quote
slick Posted May 23, 2007 Author Report Posted May 23, 2007 for the dimmer ground and the parking lights: the dimmer i just have to ground ? the parking lights to a positive? Again, it's up to you to test. If for some reason your electrical system is screwed, it could be the opposite. Quote
FordBoy Posted May 23, 2007 Report Posted May 23, 2007 ok fine damn calm down i thought you put that for the other qt Quote
AxlCrucifix Posted July 1, 2007 Report Posted July 1, 2007 i basically need to cut my plug off because no one here has the damn harness i need ive got a 1989 grand prix with the performance sound, not sure if its monsoon or bose, but its the performance sound for sure and no one has the harness to fit apparently there is a scosche one to fit but i can only find it on walmart.com and they dont ship to canada Quote
w00tah Posted April 26, 2008 Report Posted April 26, 2008 Good sticky, but what about those with Bose/Monsoon that want to bypass the factory amplification without a bypass harness? Is there Red/Yellow/Black in the Bose/Monsoon harness to use with an aftermarket deck? Reason I'm asking is if I want to use my aftermarket unit, I probably don't want to use the shitty factory amplifier to give the unmatched signal to the speakers (since this is what the Bose/Monsoon harness allows you to do). Kef Quote
slick Posted April 26, 2008 Author Report Posted April 26, 2008 The plug behind the radio is exactly the same, but there may be a pin in a normally empty location that is the amplifier turn on lead. Generally, it is a green or pink. The colors are 99.9999% the same. GM keeps pretty universal in there wire colors. Quote
1990lumina Posted December 21, 2008 Report Posted December 21, 2008 Orange = 12v Constant/Battery Yellow = 12v Switched/ACC Black = Ground Gray = dimmer ground Brown = Parking lights In my Lumina it has two brown wires to subsitute the grey and brown wires. They are brown, and brown w/ white tracer. I'd assume the brown is park lights and brown w/ white is the ground though? Quote
boymeetspavement Posted May 20, 2009 Report Posted May 20, 2009 ahh yea Ima need this tomarrow! Im going to control myself this time and do a basic audio setup. Quote
n_pants Posted October 20, 2013 Report Posted October 20, 2013 I know it's been 4 years since this thread was updated but maybe someone can help me? 1995 Oldsmobile 88 and I can't ID these wires. I have 3 yellow wires and 3 dark green wires, no pink wire. I didn't have any luck finding a wiring harness that fit, and stupidly cut the stock one before IDing any wires. As you can guess, now I can't just throw the stock head unit back in. Can someone walk me through this? Quote
ahill007ny Posted December 25, 2013 Report Posted December 25, 2013 HEY!!! DID U FIGURE THIS OUT? I HAVE A 94 LUMINA AND MY DASH ONLY LIGHTS WHEN THE RADIO IS TURNED ON AND ITS DIM I LOOKED AT THE WIRES AND I SEE THE BROWN WIRE AND THE BROWN W/ WHITE I WAS WONDERING IF THAT HAD SOMETHING TO DO WITH IT? Quote
Nick727 Posted May 4, 2024 Report Posted May 4, 2024 Does anyone have the wiring diagram for the SWC at the radio? 1993 cutlass Quote
