FordBoy Posted April 10, 2007 Report Posted April 10, 2007 as replacement motor parts? I plan to bore and stoke my 2.8 and im having a very hard time finding parts to replace the stock parts. Cuz imagine that they didnt make performace parts for the 2.8?! i cant believe it Would a 3800 crank, heads work.im thinking of getting the bore 30 over so then i would need 203mm pistons vs stock 173mm i need parts that can take power cuz i still would like to turbocharge it later on in the "new" motors life. plus a 5spd upgrade. BTW the rear honda civic buckets are almost done just a bolt here and a weld there Quote
Robby1870 Posted April 10, 2007 Report Posted April 10, 2007 First of all, "30 over" means 30 thousandths of an inch over bore, or .030in, not 30mm. 30mm is more than 1in. Secondly, no, none of the 3.8 stuff is going to work Third, if you want to stroke it, just use a 3.1L crank. Quote
J Posted April 10, 2007 Report Posted April 10, 2007 90* and 60* together NOPE! i'd just get a newer low mileage 3400 and bolt that in, it might be a lil more work due to OBDII, but more power and a better platform to start a turbo set up on. Fr the used 3400 with everything you need i could see you spending about $500 so that far outweighs the cost of getting custom pistons and other parts made. JMO later Jay EDIT ROBBIE BEAT ME TO IT! Oh and if you are dead set on rebuilding that 2.8 (i don't know why you would) i'd get the bores honed to clean them up and not worry about boring it over, then having to worry about compression for the turbo set-up Quote
Robby1870 Posted April 10, 2007 Report Posted April 10, 2007 FYI: 0.75mm is approximately .030in. So, if you wanted to bore it, look for pistons that say something like 89mm +0.75mm Quote
88Regal Limited Posted April 10, 2007 Report Posted April 10, 2007 uhh, a 3800 is a 90* motor. The 2.8/3.1/3100/3400 etc are 60* motors. Just do a 3400 or 3800 swap and be done with it. Even I know the 2.8 is worthless in a heavy ass car like mine. In a chevette or cavalier on the other hand..... Quote
digitaloutsider Posted April 10, 2007 Report Posted April 10, 2007 Why bother with the motor when the rest of the car is so beat? I don't understand this mentality. Quote
joey b Posted April 10, 2007 Report Posted April 10, 2007 How many of these threads are you going to start? Seems to be once a month you ask a similar question and always get the same result. Quote
FordBoy Posted April 10, 2007 Author Report Posted April 10, 2007 i meant 3400 fine if you guys think that it is a bad idea i wont let you know the process its that simple. just because you wouldnt do doesnt mean i dont want to about the way the car looks fuck the looks it will be a "sleeper" look like shit but haul ass if your sick of seeiing me post about what i want to do to it then dont read it/open it Quote
pwmin Posted April 10, 2007 Report Posted April 10, 2007 geez, people, lighten up. i dont know how many posts people start w/ just a link to a website or video. its called a sleeper Quote
RJansen658 Posted April 11, 2007 Report Posted April 11, 2007 FordBoy, this site has everything you could possibly need: http://www.engine-parts.com/ Quote
FordBoy Posted April 11, 2007 Author Report Posted April 11, 2007 FordBoy, this site has everything you could possibly need: http://www.engine-parts.com/ thanks that helps Quote
19Cutlass94 Posted April 11, 2007 Report Posted April 11, 2007 I dont wanna burst your bubble there, but a stock 3400 will make more power than you "modded" 2.8........... Quote
FordBoy Posted April 12, 2007 Author Report Posted April 12, 2007 thanks again BTW your telling me that a stock 3400 would have more power then a bored, stroked, turbo, 5spd 2.8 i call bs on that Quote
digitaloutsider Posted April 12, 2007 Report Posted April 12, 2007 Boring does nothing, stroking is worhless on that motor, and for the cost of a fucking turbocharger setup, you could have an intercooled L67 that runs low 12's. WHY fuck with the 2.8?! Quote
Euro Posted April 12, 2007 Report Posted April 12, 2007 thanks again BTW your telling me that a stock 3400 would have more power then a bored, stroked, turbo, 5spd 2.8 i call bs on that yep.... Quote
digitaloutsider Posted April 12, 2007 Report Posted April 12, 2007 After doing all that to the 2.8, you just might be able to hang with a slightly modded 5-speed LQ1. Congratulations. Do you have any concept of the complexity of picking out the right turbo with the right A/R ratios? Do you know what goes into TUNING such an automobile? Do you have the know-how to calculate air/fuel and spark tables? When it comes right down to it, if you have a naturally aspirated 2.8/3.1, and you want power, as much as it pains me to say it, your best bet is finding a low milage L67/4T65E-HD with all the associated wiring and the PCM and convert your car to OBD-II. Tuning with OBD-I, especially with boost, is a nightmare. Ask the TGP guys. If you're feeling adventurous, swap to the LQ1 and the 284 and go from there. As I've said in previous threads, the 3.4 DOHC has plenty of untapped potential regarding boost. The only way I could even fathom doing ANYTHING to a N/A 2.8/3.1 would be if i found a TGP setup for cheap. Other than that, fuck that motor. You're not going to get any power out of it without spending ridiculously large amounts of money. And even then, someone with an LQ1/L67 could spend even HALF that and smoke your ass. Quote
FordBoy Posted April 12, 2007 Author Report Posted April 12, 2007 it what i want to do why are you telling me that what i want to do is a waste of time and money. that is your opinion i dont care what anyone says to me about it being stupid or a waste of tiime to mod a 2.8. you dont like it then ignore the post you have that right i want to be different (not alot of modded 2.8s) everyone throws a l67 in any W and says its the best thing they ever did fine by me. you want to do it i support you. in return i ask that you support me when i tell you what im GOING to do to my motor. people completely redo a 3.1 know says a word to them about it not being worth it. i bring up a 2.8 and i hear its not worth it they a pretty much the same motor one is just a little bigger stroke. Bottom line is if you dont like it leave it alone dont put in your input if it is insulting to someone. come on questioning my knowlegde of cars that is an insult to me (IMO) you dont know me im not trying to be a dick about it i just dont want people telling me that i shouldnt do it cause its a waste of time and money. it doesnt affect you so why do you care how or what i do to my car? Quote
Euro Posted April 12, 2007 Report Posted April 12, 2007 well when you ask/tell on a public CAR forum you're going to get people's opinions no matter what. We're not necessarily just hating on you, we're just saying this because it IS worthless to dump all this money into your 2.8 so you can go from high 17's to MAYBE mid/high 16's Quote
19Cutlass94 Posted April 12, 2007 Report Posted April 12, 2007 By the time you spend all that money on that 2.8, you can have a modded 3400 and be running 14's.... Quote
GP1138 Posted April 13, 2007 Report Posted April 13, 2007 well when you ask/tell on a public CAR forum you're going to get people's opinions no matter what. x2 And I would go with the 3400. So much more potential, IMO. Quote
Addicted To Boost Posted April 13, 2007 Report Posted April 13, 2007 Let him do what HE wants guys.... to me at least, it is pretty apparent to what he wants/intends to do. Go for it man. Quote
rockfangd Posted April 13, 2007 Report Posted April 13, 2007 also, try http://www.rockauto.com \rockauto is highly reccomended. i have saved tons of money for myself and my customers. Quote
Dark Ride Posted April 13, 2007 Report Posted April 13, 2007 thanks again BTW your telling me that a stock 3400 would have more power then a bored, stroked, turbo, 5spd 2.8 i call bs on that a stroked 2.8 = 3.1 boring a 3.1 30 over = 3.2 a 3.2 with a turbo and a 5 spd does have potential, but why spend so much money to fight with the 2.8/3.1 setup? You should get an LQ1 with a 5 spd and make a custom turbo setup, Now that would be sweet! I understand having a sleeper is cool, but don't you wanna pick up chicks at the same time? Your car isn't exactly show off material. Quote
digitaloutsider Posted April 13, 2007 Report Posted April 13, 2007 come on questioning my knowlegde of cars that is an insult to me (IMO) Most people who would even think about OMG STROKIN' AND TURBOIN' MAH 2.8 don't know SHIT about either of those processes. They especially don't know a thing about tuning. That's why I jumped to such a conclusion. Anyway. I'm leaving you alone now. Pissing away money is your problem, not mine. See you at the track. Quote
