jc whitney sells drilled rotors but there only listed for 90-95 lumina. I have a 93 cutlass and I'm sure they will fit but I need to know for sure so I don't buy them for nothing. any input is appreciated :biggrin:
Unless its a JC Whitney white box special, it doesnt matter where you got your parts from. I got my ST springs from JC Whitney.... If its name brand, whats the problem with getting them from there?!
I got the GM Performance Slotted Rotors on my White Lumina, and I love em. Got Ceramic Pads Too, But Not GM.
Now, based on the fact that you are buying drilled and slotted rotors, I assume you are trying to upgrade your brakes. IMO, the best thing you could do, would be go to a junkyard, and get the entire front strut assembly from a 96'-97' Lumina or Monte. Then get drilled and slotted rotors for those if you must. You will get bigger diameter rotors. You can do the same for the rears since you have a 93'. Just get the bigger 94+? rear caliper bracket, calipers and rotors and your good to go. They are bigger all the way around on the rears, I believe the front upgrade uses the same calipers.
I got my ST springs from jc also. I have never had any problems with name brand parts from jc :cool:
i also got my St springs from them, but the 2 times i ordered brake parts from them they were cheap crap even if they claimed they were the quality stuff. It may work out for you, it's JMO
  • 2 weeks later...
Anyone got a part number on those GMPP rotors? Are they pre 94 friendly?
?? GMPP doesn't make performance rotors for our cars.
dude i bought GMPP Slotted rotors from the GM Dealer I worked at, there whats on my white sedan. Matter of fact I think i got the catalog i stole somewhere round here............
I use SP Performance slotted rotors and Hawk/Rofren pads, and I've been very pleased with them
Rotorworks and Bendix pads are what I use.
where did you get your rotors from?
Rotorworks on eBay
thanks :thumb: I will probably be doing the brakes sometime soon for the monte
Rotorworks on eBay
It's a good upgrade, try and get the Bendix Ceramic CT3 pads. It makes a nice combo.
