Alright, been doing some thinking. I know the 3100 heads will bolt to my block, BUT, will my lower intake bolt to the 3100 heads? I like the long runners on my lower intake, for good low end torque. From some pics I have of the two, it looks like my lower intake would bolt to them. Are the valves on the 3100 splayed, like mine? One pic I have shows them to be lie mine. Cuz, I woud like to be able to use my rockers on the 3100 heads. Just wondering, cuz like I said, I been doing some thinking about where to take this motor. Oh, and using the 3100 heads wouldnt change my compression ratio, right? (and I know I would need the 3100 exhaust manifolds)
Robby
Guest TurboSedan
oh someone does, c'mon.....
i don't myself really, i have never even had the 3.1 or 3100 apart that far! i will be shortly tho :) otherwise you could check http://www.60degreev6.com
good luck
joshua
Well, here's the pics (from Vegeta's site), that I have referred to
My Gen 2 is on the top of each pic, and Gen 3 is on the bottom
COPY/PASTE!!
http://members.fortunecity.com/robby1870/gen2vsgen3intake.html
http://members.fortunecity.com/robby1870/gen2vsgen3exhaust.html
http://members.fortunecity.com/robby1870/gen2vsgen3cc.html
I know the patterns of the intakes are different, but I would port/polish heads and intakes anyway, and then just match them up. And, use my rockers if I can.
Robby
The gen 2 manifolds are longer but not by much. Going to a gen 3 setup will do lots. As far as Im concerned the lower gen 2 won't bolt up to a gen 3 set of heads, but I gotta ask why you want 3100 heads in the first place! The heads will not change the compression ratio
Well, I been doing some thinking. And, from what I have heard, a ported/polished 3.1L head flows about as well as a stock 3100 head. So if I port/polish a 3100 head, even better flow. But, why I ask is that my sister had a pretty good size wreck in her 96 GP (with 3100), it wasnt her fault, and everyone was okay, but, if it is totaled, I want to buy it and use whatever I can from it (and sell what I can, cuz the interior is excellent shape). Im just thinking of where I want to take my motor as far as performance. I know it wont raise compression, but, some day, higer compression pistons will. I just dont know if want to build a n/a low-end torque monster or a high-boosting high-end HP animal. Im just trying to think of ways to get performance and what would swap over. Another reason I ask is that I want to keep my plenum, which would mean my lower intake too, cuz I want the motor to look original. Plus, I dont want to swap over all the other stuff, sensor placement what not. Well, thats the story.
Robby
