stockgp Posted April 14, 2007 Author Report Posted April 14, 2007 ok, so there's no coolant in the oil. and apparently no oil in the coolant. replaced the thermostat, stil overheating. if you turn the heat on in the car, it's only hot for a second. after that it's only cold air. seems to be air in the system, but even if you bleed it off, the temp only goes down for a few seconds. if you rev the engine after letting it warm up, sound like it's backfiring a bit. if i ground both fans, the temp will stay around 240, but no lower. anyone have any ideas? if i can't think of something soon, it's probably going to get traded in for something newer Quote
Brian P Posted April 15, 2007 Report Posted April 15, 2007 do a compression test on all cylinders. Quote
Crazy K Posted April 15, 2007 Report Posted April 15, 2007 just to be sure, you have verified the guage is working? mine does not work right on my 95 CS sedan. why not just throw is a later model large intake 3100 or 3400? Quote
ismellrealbad Posted April 15, 2007 Report Posted April 15, 2007 hes got no heat, so it probably is....warped or cracked head (such as from a not checking things after a previous gasket job) can allow cylinder compression to enter cooling system Quote
grand prix Posted April 15, 2007 Report Posted April 15, 2007 my dodge van did the bubbling coolant thing and overheated, turned out to be a bad rad cap, Quote
stockgp Posted April 15, 2007 Author Report Posted April 15, 2007 puttin a new motor in is going to cost a lot more than a newer motor. my parents weren't thrilled about putting 200 bucks into new head gaskets. i'm going ot check all the plugs to see if any are wet. after that, i imagine she'll be going to the junk yard. i might save the motor for my turbo 3100. but, given it's questionable history, i don't know. Quote
chadz34 Posted April 16, 2007 Report Posted April 16, 2007 I blew a headgasket on a 96 DOHC......Apparently its rare. Quote
