it's a wonderful life...
just found out my mom's lumi has a suspect head gasket. this after i found out my car blew an intake gasket yesterday.
so hopefully i get mine back together today so i can start on hers tomorrow.
how common is it for 60* motors to blow a head gasket? it's my understanding that this isn't the first time this car has blown a head gasket. has a new radiator and thermostat as of last summer. roughly 180,000 miles on it, but it still runs excellent.
i'm assuming it's a head gasket because under heavy acceleration it's getting something like gas knock. also, the coolant is bubbling back into the reservoir and there's a little pudding in there.
damn i hate w bodies. if this shit keeps going on, my family is going to be w free very soon...
Someone is having some bad luck
problems happen on cars its a thing of nature
"Shit Happens"
I've never had a problem with headgaskets on 60*, in fact, I don't that it's very common at all.
My 89 blew a head gasket around 160k.
It's the only one so far though.
i didn't think it was all that common. but i know this is at least the second time the lumi has blown a head gasket.
  Quote
"Shit Happens"
gtfo of my thread. i' ve had enough of these evil bitches. i'm allowed to be pissed if i want :lol:
From my experience, a head gasket going above 150k is very common on almost any engine no matter how well designed. These things are made out of a composite material and due to the fact that its a bi-metal mating surface (Aluminum Head on Iron Block), the heads "scrub" a little on expansion and contraction, causing the gasket to eventually wear out.
So needless to say you shouldn't be so pissed.
This is why I support the duke, all made from pig iron.
Id be willing to bet motors that don't live in extreme temp climates and are given a chance to warm up (allowing both metals to expand) before driving have less head gasket issues.
I've owned lots of 60 Degree V-6 cars and NEVER blew a head gasket. Lower intake gaskets, had to replace 2 sets due to leakage. But never the head gasket.
Considering the mileage though, maybe it was due. Depends on how well it was maintained, usually they don't just blow. First they will overheat (maybe due to thermostat failure) and then will blow due to the overheating.
pretty unusual! at least on my car which is giving me overheat lights and such, I have no such signs!
the lumi hasn't overheated yet. the coolant light has come on a few times and started running a little rough yesterday. other than that there have been no telltale signs.
My 3.1 blew a head gasket at ~170k
and wait, you live in WV? anywhere near the Ohio border?
I doubt it. Mine didn't fail from any kind of shearing action of dissimilar metals expanding at different rates. It failed because the coolant passages rotted from the inside-out.
  Quote
yes, but nowhere near chillicothe. i'm in the northernmost part of wv, 40 minutes west of pittsburgh, 5 minutes from the ohio and pennsylvania borders
and yay for rotting coolant passages. at this opint, my step dad isn't sure he wants to put any more money into it. he's considering trading it in (not that he'd get anything out of it) for a cheapie korean car. after i told it's going to be around $215 in parts he seemed pretty set on getting rid of it
I have to question the quality of the last head gasket job, if it failed in short order.
Better check the block surface and head surface for straightness. I agree w/Brian P, for it to go that soon after the last repair suggests another hidden problem.
i don't know that it's the same head gasket that went. i don't know which head gasket was replaced. all i know is that the last lady that owned it had one head gasket replaced.
if you end up wanting a hand with it i could come down and help out possably.
why would you only replace one? I know it wasn't you.. but still, that makes no sense. if one's going to go the other's sure to follow soon enough.
who knows. the guy that did all of that lady's work was a little shady.
shit, my mom took the lumi to that guy to get it inspected, and they torqued a couple lug nuts down so tight i couldn't break them loose even by jumping on a 24" breaker bar.
so, he may have replaced both head gaskets. but, i wouldn't be surpised if he only did one.
  stockgp said:
  Quote
Oh I don't live in Chillicothe anymore, my parents do, but I haven't been back in a few weeks, I live in Athens, OH, but I've been hanging out a lot in Parkersburg too, it's only 20 minutes from my house
ah. parkersburg is closer, but still a good clip from me.
and i guess i'm going to change the t-stat and see what happens. my brother is insisting that's what it is. i don't think so, but i hope he's right.
Any mechanic that agreed to do just one head gasket is not the mechanic to use. There is absolutely no reason not to do them both, especially on a 3.1L/3100.
When it is apart you should ask to see the block and head surfaces after they have been cleaned, it may not even be worth putting another gasket set on if the block has been damaged by a less than apt mechanic... at least not without decking it.
