Guest Anonymous Posted June 16, 2003 Report Posted June 16, 2003 My neighbor has a '90(?) lumina 3.1. A few weeks ago something happened with the tranny. They started it and when they put it in gear nothing happened. No noise, nothing. The shifter cable isn't broke, I checked that first. I can hear the s4elector moving in the tranny but that's it. There are no other noises and no movement. Any ideas? Quote
Redfox340 Posted June 16, 2003 Report Posted June 16, 2003 Obvious question I bet, but is there fluid on the dipstick? - RedFox340 Quote
KrazyCutlass1995 Posted June 17, 2003 Report Posted June 17, 2003 well im not sure how the fuses are on the lumina , but on my cutty there is a fuse for the tranny on passenger side under the hood , i had this problem before and i replaced the fuse and it was all good then ... take a look and see if it has a fuse , if so it may be blown Quote
Guest Anonymous Posted June 17, 2003 Report Posted June 17, 2003 Yes, there is fluid on the dipstick. I'll check for that fuse right now. Quote
NOHC_WBody Posted June 18, 2003 Report Posted June 18, 2003 No drive in any gear? forward or reverse? Quote
Slade901 Posted June 18, 2003 Report Posted June 18, 2003 Set the emergency brake, start the car, put the gear in Drive, then check the fluid level and topped it off to the max and then hit the brake while releasing the emergency brake. Check to ee if the car moves then. Quote
luminator94 Posted June 18, 2003 Report Posted June 18, 2003 Vacuum line possibly? I remember when I had my 94 Euro(4T60-E), sometimes I would get to a stop sign, stop, hit the gas to go, and the engine would just rev! I would have to put the car back into park for a couple seconds, then back into D and off I'd go. GM has some of the weirdest trannies I've ever experienced. Aaron Quote
Guest Anonymous Posted June 19, 2003 Report Posted June 19, 2003 Does the 4t60-e use the vacuum line that comes off the plenum behind the TB? I think someone said before it does but I'm not sure. Quote
Guest Anonymous Posted June 21, 2003 Report Posted June 21, 2003 Damn! I thought somewould on here had a 4t60-e. Guess not. Seriously, noone knows? Quote
Robby1870 Posted June 21, 2003 Report Posted June 21, 2003 Im pretty sure it does use that line, I would go look on my sis's 96 GP with 3100, but its totaled. Anyway, I really think the 4T60E does use that vacuum line (dont know if its in the same place as for 3.1L/4T60). Robby Quote
patgizz Posted June 21, 2003 Report Posted June 21, 2003 next obvious thing: torque converter to flywheel bolts. they there? i've had them sheer off before. Quote
Guest Anonymous Posted June 22, 2003 Report Posted June 22, 2003 Im pretty sure it does use that line, I would go look on my sis's 96 GP with 3100, but its totaled. Anyway, I really think the 4T60E does use that vacuum line (dont know if its in the same place as for 3.1L/4T60). Robby Like the dumbass I am, I forgot I have a 4t60-e sitting in my driveway in the '94 CS. It does have the vacuum line. I looked at another '90 Lumina today and it was the same way as my neighbors. The nipple on the intake has a vacuum plug on it. I don't understand that. BTW: I have a pic of the Lumina I looked at today. It was in a car show. I'm going to post it in the whatever section later if anyone wants to see it. Quote
Robby1870 Posted June 22, 2003 Report Posted June 22, 2003 yeah, I forgot you had the CS in your driveway too. But, you should have remembered before anyone else on here!! So on your CS plenum, there is a nipple?? I know on my 3.1L its a screw in connection. Wonder why they decided on a nipple?? Robby Quote
Guest Anonymous Posted June 22, 2003 Report Posted June 22, 2003 On my CS the nipple pushes into the plenum. Quote
