Does anyone know where I can get some slotted/cross drilled brake rotors for the front and rear on my 1993 Cutlass Supreme (SL)?
There is a guy on eBay named "rotorworks" and he did mine. They are awesome quality and he "zinc coats" the rotors so the only spot that has rusted for me is inside the drills. The hats and outer edges are still silver.
Ummm may I make a suggestion?
I would say, you should buy slotted rear rotors for the 94+ G.P. since they are a bit bigger, and do the 94+ rear upgrade. All you need is the rotors, rear calipers, and rear caliper brackets. It is a much better braking system than the stock 93' system, and it is a bolt on swap, no modification required...
x2! done this swap... uhhh 3 times i think? I lost count!
here's a good how to. plus the 94+ calipers are easy to get in good condition used.
http://tpsgarage.com/TGP/brakes/rear_brake_upgrade.htm
No longer a registered user. Had really bad feedback. Just thought I would update that, at least.
