Weird Suspension Prob.
Ok, when I drive under 45 my steering wheel shakes(alot).... the car does too (alittle) but the wheel is crazy.... I know I need a alighnment, but could that 'just' be it??? Thanks
Yeah, it could be that.
Also, have you had your tires rotated / balanced lately?
Did you do a panic stop lately? If so, that could of flat-spotted the tires.
- RedFox340
wat happens when you flat spot a tire? how can this be correted?
In a panic brake situtation or a e-brake slide or stop.
Either you deal with the vibration or replace the tire.
When flat-spotted, you'v loss tread wear big enough to where it's not a complete circle anymore.
The "flat-spot" hits the road and as results, can give the vehicle vibrations.
- RedFox340
I think its just aligment/balance/rotation. Its hard to flat spot stock tires, cuz they use such hard compounds to make them last longer, but its still a possibility
Robby
