How to lower a W-Body ( Gen 1, Gen 1.5 )
just ordered nuts and sleeves for my rear coilovers. im probably going to wait till next month to order my springs. i found a black nut while looking at the a1racing.com website and ordered that (http://www.a1racing.com/index.asp?PageAction=VIEWPROD&ProdID=1746). its the same price as the gold ones, but has more holes for a spanner wrench, which i dont care about, but its black instead of gold. so, im going to have black sleeves and black nuts w/ red coils. im going to get these springs and have them powdercoated red: http://store.summitracing.com/partdetail.asp?autofilter=1&part=HAL%2D12%2D175%2D350&N=700+4294925130+4294846689+4294791365+4294787535+4294868465+115&autoview=sku
  • 2 months later...
First post has been updated.
:thumb:
i would add this link under the black coilover nut. it has set screws, but is gold. i havent had any problems w/ the black one (no set screws)moving, but its def possible.
http://www.a1racing.com/index.asp?PageAction=VIEWPROD&ProdID=1744
i would also add this link for springs (any of these can be used):
http://store.summitracing.com/egnsearch.asp?N=700+4294925130+4294846689+4294791365+115+4294787535
:thumb:
i would add this link under the black coilover nut. it has set screws' date=' but is gold. i havent had any problems w/ the black one (no set screws)moving, but its def possible.
[/quote']
That looks to be the exact adjuster nut that comes with the Held Coil over kits.
Jay, you can take underbody reconditioning off that list, I never did get around to that, ran outta time. Maybe next summer, who knows.
Jamie
So I have a 95 GP 4door se isn't this car 1.5 gen? The problem I have is that it has the mono leaf suspension and I thought that was only a gen 1 thing whats up please help. :willynilly:
the only cars that are 1.5 gen are the lumina 1995-2001 and the monte 1995-1999 thats it, best and easieest way to tell, its all in the rear end, look at your rear strut mounts, the 1.5 gens use 3 bolt strut mounts like 2nd gen Gp's and regals, and 1st gens use a 2 bolt design that will fit aweb's rear stb
Thanks for the info :high5: I will have to search that aweb's rear stb thing. :cool: Unless someone wants to hand feed it to me. :mrgreen:
look in the group buy section
  • 2 months later...
First post updated due to dead links. Also fixed a few things.
Any questions please let me know!
and
BUMPING THIS SO PEOPLE KNOW WHERE TO LOOK SO THEY STOP ASKING QUESTIONS BECAUSE THE ANSWERS ARE IN THIS THREAD.
  • 4 months later...
so to drop the front of my car ALL I need is to buy is the spings and change them??? NOTHING else??? I'm confussed :redface:
I would recommend new struts as well. You will blow the stockers if you don't.
yes all you need is to change out the front springs......
  • 10 months later...
there are pics all over this site. check out the links in my sig for pix of the two i had lowered
Here's another for the lowered pics:
This job was done with KYB GR2 shocks all around, KYB strut mounts all around, Suspension Techniques springs up front, and a custom fabricated Flex-A-Form rear leaf.
  • 8 months later...
So Im going to try an update this thread, since this topic always seems to be coming up. So anyone with some new information please post so I can better update first post.
  • 3 months later...
wanted to add that Intrax springs on 1st gen cars will drop the front suspension *at least* 3.5". before someone orders a 2 inch rear drop spring from birchmount like I did. another thing to watch out for is a 2" drop birchmount spring with pucks is same as stock pretty much. you would need more like 4 1/2" birchmount spring for it to be a close match with the intrax fronts.
my tgp has a 3" drop birchmount, with shaved pucks (1/3 the thickness of normal) and intraxs up front.
sitting on 245-45-16
my front end almost looked lower than that with the intrax springs for some reason. not sure why the rear didn't drop at all but I might go and shave the pucks at least.
What side of the puck do you shave?
I want that ride height.
mine were solid, so the flat side, not the side with the machined groove
That valance is a 2 yr old GM NOS unit that has no sag, hence the not slammed appearance out front.
