Robby1870 Posted June 15, 2003 Report Posted June 15, 2003 Well, got the rockers in, new O2, cleaned injectors, new pushrods, adjustable vacuum modualtor. I got the MAP problem fixed. So, the cars runs so much better. The rockers mad a big difference, especially around 3K-5K rpms. Got the adjustable modulator tuned to my liking, and I love it. I didnt know the 4T60 was capable of such quick and precise shifts. Now, shifting into 2nd at WOT, the car is a handful to keep straight. I by-passed the TB coolant lines and changed oil-pump drive O-ring as well. Just wanted to let everyone know I got it done (for those who care ) EDIT: I recommend to anyone who takes their plenum off, to get BRAND NEW bolts for it. I broke two off, and one that I broke off wasnt even torqued to spec. Just a suggestion Robby Quote
mdelorie Posted June 15, 2003 Report Posted June 15, 2003 Sounds sweet! I want rockers! question though. I just blew one of my TB coolant hoses today. What's the scoop on the whole bypass? why should I do it? why shouldn't I? How can I? Quote
gmrulz4u Posted June 15, 2003 Report Posted June 15, 2003 That's awsome! I also have a question: What exactly was your "MAP problem"?? THANKS:) Quote
Slade901 Posted June 15, 2003 Report Posted June 15, 2003 TB coolant line was supposedly meant to help the TB warmed up on a very very cold climate but for folks that does not live in a very very cold climate the TB coolant line just add additional warm to the air intake. You want to have a cold intake and so by-passing the TB coolant line would help your air intake to be cooler. Quote
Robby1870 Posted June 15, 2003 Author Report Posted June 15, 2003 The MAP problem ended up being a broken/pinched vacuum line. I thought it was intact, until I ran the car, and took off the vacuum line to the MAP since I was gettin a MAP code, and felt NO vacuum at idle, which is wrong. So, I ran a new line from the elbow at the fuel pressure regulator to the MAP, problem solved Slade901 explained the TB coolant by-pass perfect Robby Quote
mdelorie Posted June 15, 2003 Report Posted June 15, 2003 I shouldn't notice any differences in bypassing it? I'm just kind of weary... Quote
Robby1870 Posted June 15, 2003 Author Report Posted June 15, 2003 No, you wont notice any adverse side-effects in the summer. If you live in VERY VERY cold climates, during the winter you might. You might even notice a small pick up in MPG once the motor is warm Robby Quote
mdelorie Posted June 15, 2003 Report Posted June 15, 2003 How would I go about doing this? can I get a normal piece of hose to fit? And thend just leave the TB fittings hanging there. Quote
GrandPrix34 Posted June 15, 2003 Report Posted June 15, 2003 great job robby! How does the car feel in terms of poop-o-meter? Quote
Slade901 Posted June 16, 2003 Report Posted June 16, 2003 It should be similar to this link http://www.v6z24.com/mods/howto/?page=heaterbypass Quote
Robby1870 Posted June 16, 2003 Author Report Posted June 16, 2003 How would I go about doing this? can I get a normal piece of hose to fit? And thend just leave the TB fittings hanging there. You will need an L-bend and its 5/8 in inner diameter. You cant use a a straight piece, it kinks up. I know a guy at my local Advance, and he gave me the L-bend for free. You can leave the old lines connected to the TB. I didnt b/c I had to take the TB off. GrandPrix34, the car has a lot more get-up-and-go. Better low end torque, and high end HP. And, 2nd gear actually feels like it pulls some now!! The tranny is a great compliment. With the tranny adjusted, the car "feels" a lot more sportier and faster. Overall, the project was well worth it, plus I got my oil leak stopped. It had gotten to where I was using about a quart every week or two (damn O-ring) Robby Quote
mdelorie Posted June 16, 2003 Report Posted June 16, 2003 Thanks guys! Got 'er all done today! but just read the posts now. It was totally easy - bought a "cut-to fit" elbow joint, a couple gear clamps, and tossed it on.. it was simple. Didn't have to take off the TB or anything. Robby, you oughta write a "how-to" on that one. Give all us other guys motivation to do the same. It sounds like some really worth-while mods. Quote
Robby1870 Posted June 16, 2003 Author Report Posted June 16, 2003 Im going to do a how to when I get some extra time, and my pics scanned and on my computer. Robby Quote
