gmrulz4u Posted June 15, 2003 Report Posted June 15, 2003 How are the door moldings on the Cutlass International's HELD ON? I recently had my Cutty completely re-painted but now when I open the drivers side door, the molding on the door is "catching" the other side and coming off... I'm affraid to open the door to fast or too hard now because it keeps leaving little scratches and gets worse and worse(coming off) each time... I was thinking of using some type of glue, but that seems too ghetto? HELP! Quote
Justin Posted June 15, 2003 Report Posted June 15, 2003 There's a series of screws or bolts on the lower edge of it, look under your door. Then you lift the moulding upwards, it's just held in by some big clips. I think there's a screw that should be in the upper front corner of the moulding, maybe it's been left out when they put the panel back on. If they took it off, that is. The screw(if there is one) should go in from behind, you can see it when the door is open. Quote
