im guessing that those are for the gen 1.5 lumina and montes, so the fronts would work, but not the rears
would the fronts and rears be the same? or are there differences?
The fronts will work. The rears wont for this difference, we dont have rear springs.....................
well yeah, but I was askin' are all 4 the same spring? Or are the fronts/rears different from each other
excuse me for being a retard, but did the 95 monte have a different rear suspension setup than the cutlass? this says it works but i dont know where the hell id mount coil springs on the back of my car haha...
did the later w's have rear coil-overs? how hard would these be to adapt to my car (if they exist)? I mean, can i get this kit and some parts from a junkyard and be all set to go? my car sits waaaay too high as you can see
yeah. the 95-99 Monte Carlo/Lumina sat on a different rear suspension. They didn't have the monoleaf like you do. You'd have to pull the monoleaf, swap in the rear suspension from a 1.5 gen monte/lumina and go from there.
so would there be any real downside to getting a 1.5 suspension in back, because then you could just get lowering springs for the rear, right? or is there something I'm missing?
just get coilovers instead of swapping to gen 1.5...not worth it IMO. the downside is if you get the eibachs for a 1.5, the front sits lower than the rear and looks weird, at least every one ive seen.
well I lost track of that rear coilover thread and where it was going, so I wasn't sure if those would be an option down the road, so I figured this might be an acceptable substitute at some point if need be
hmm, nothing ni them looks to definitive, but it looks like I can do it cheaper if I get things seperately. I have the front springs, and plan on ordering some KYB's at all 4 corners here soon, so I have to figure out what to do in the rear :-?
Dude, seriously how many times is this question going to be asked. You guys want to lower your cars and you don't even know the general make-up of the rear suspension!?
Sorry to sound like an ass, but damn already. I must have seen Jay saying this 3 to 4 times already to different people.
That one is good, and so is this: It even has part numbers!!!1111BBQ
http://www.w-body.com/forum/index.php/topic,51716.0.html
People here just need to take the time and research this stuff instead of complaining about it. 99% of the parts are from AFCO Racing. And when you build your own, youll pretty much have a choice in what you want in spring rates and a couple other areas.
